Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 12-15-2005, 11:50 AM   #1
carguy4
Member#: 58073
2002 impreza 2.5 ts
deep saphire blue
Default 2002 2.5 SOHC timing belt replacement
I was wondering if anyone knows where I can get my hands on an
article from endwrench to change my timing belt
I have done a search and found a good one for a DOHC 2.5 but was wondering if anyone has a link to an article or maybe even a post for a 2.5 SOHC timing belt replacement
thanks
james
carguy4 is offline   Reply With Quote
Old 12-15-2005, 01:40 PM   #2
Hayes
Member#: 11808
I just changed the timing belt on my 2.5L SOHC Forester engine using the DOHC endwrench article. There is no difference except you do not need to lock the camshafts when removing the timing belt. Be prepared to remove the crankshaft bolt as the torque spec is 130 foot pounds and it appears to have a locktight coating on the threads which appeared to require ~ 200 + foot pounds force to remove it. The bolt size is, I think 22 mm and use a 1/2 inch drive-6 point impact socket and a breaker bar + 3 foot pipe extension. There is a inspection hole on the left side of the engine bellhousing (standing in front) that when removed will allow you to lock the flywheel with a strong screwdriver. I also removed the radiator and cooling fans as a unit rather than seperately. The job took me and a friend about 2 & 1.2 hours with a few short breaks. O-YES rotate the crankshaft (timing belt on) untill ALL the timing marks are aligned. The new belt will have lines on them for the two cams and crankshaft. I used a drill press to reset the tensioner and you must compress it very slowly to avoid damage to the 100 dollar part. WOW was I long winded but, hope it gives some insight.
Hayes is offline   Reply With Quote
Old 12-15-2005, 03:10 PM   #3
i102spd
Member#: 92130
2002 2.5rs
i've got the dealer suby service manuals at home... havent looked thru them much but im' sure the process is in there... i'll look tonite and assuming it gives step by step instructions you can PM me a fax number and i'll copy and fax em over to you tonite or tomor
i102spd is offline   Reply With Quote
Old 12-15-2005, 03:39 PM   #4
carguy4
Member#: 58073
2002 impreza 2.5 ts
deep saphire blue
do I have to remove the pulleys, I was just planning on changing the belt. I don't really want to get into changing all the seals. I may do the water pump. I guess it all depends on how it looks under the cover. i may just pop the covers off before ordering the parts to see if the seals are starting to leak.
i102spd
that would be great. let me know when you have had a chance to look into it and I will get you a fax #
Old 12-15-2005, 03:46 PM   #5
Hayes
Member#: 11808
Yes; you do need to remove the crankshaft pulley and the belt tensioner (to reset the tensioner). I also have the OEM engine manual and while useful the step by step from www.endwrench.com was better. I also changed my waterpump and did a seal check. Nothing showed any evidance of leaking so I replaced no seals. My waterpump seemed as new but, changed it anyway as I don't want to be replace it in another 20-40,000 miles. I used an OEM timing belt but, found a new Bosch waterpump at PepBoys for ~1/2 the price of the OEM pump. IMO Ed
Old 12-15-2005, 07:11 PM   #6
i102spd
Member#: 92130
2002 2.5rs
i do have it in the book...im actually scanning the pages now so PM me your email and i'll send em off to you... it'll be clearer than faxing... not sure if it'll answer all your questions but it should be a good start
Old 12-16-2005, 11:36 AM   #7
carguy4
Member#: 58073
2002 impreza 2.5 ts
deep saphire blue
i thought removing the tensioner would be enough to get the belt off
is there a specific reason why you have to remove the crank pulley other than if you were changing the crank seal
Old 12-16-2005, 12:04 PM   #8
i102spd
Member#: 92130
2002 2.5rs
are you sure you're not thinking of the V belt? you need to pull the crank pulley to remove the belt cover and gain access to the timing belt... the crank pulley sits right in the middle of the timing belt cover
2nd reason to remove crank pulley - to replace it w/ a lightweight one
Old 12-17-2005, 08:55 PM   #9
carguy4
Member#: 58073
2002 impreza 2.5 ts
deep saphire blue
thanks a lot i102spd
i just printed your pictures and as I was reading it clicked that I needed to get the pulley off to remove the timing cover I was thinking of the sprocket but I hadn't thought of the pulley for the v-belts.
thanks for all the info everyone
so no one has come across an endwrench article for a 2.5 sohc engine. my girlfriend has a 1998 imp. with a 2.2 and I found that one and I also found a 2.5 dohc article but no such luck for a sohc engine.
Old 12-19-2005, 02:50 PM   #10
mrdezyne
Member#: 97735
Go back to endwrench....
Click on archives...
Go to system search and select engine Mechanical....
Second listing from the top is "T-Belt Time: All About Subaru OHC Timing Belts"
It has pics and diagrams of an SOHC in this article..... good luck...
mrdezyne is offline   Reply With Quote
FS: 02- up 2.5 SOHC timing belt and p/s pump xblackdeathx RMIC Private Classifieds 3 04-24-2010 10:42 AM
2.5 SOHC Timing w/o belt marks dimunation Normally Aspirated Powertrain 6 12-23-2006 01:16 PM
2.5 SOHC Timing Belt Replacement Parts serendipity Service & Maintenance 9 09-24-2005 01:08 PM
HELP! 2.5 RS Timing Belt Replacement? Have I screwed up. w chapman Normally Aspirated Powertrain 2 04-28-2005 05:37 PM
2.5 DOHC Timing Belt Replacement procedure vvk Service & Maintenance 2 07-24-2002 01:48 PM
