Old 12-15-2005, 12:44 PM   #1
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Default Need suggestions on seat and harness
Since buying my car back in June I've been slowly prepping for Solo2 STX. I did manage to run the season ender here in the Detroit Region and did quite well. And so I've decided to go even further and see if I can manage to win an event.
After that one event sliding across the seat and almost across the car, I figured that a harness was going to be necessary. I've also noticed that the newer subaru seats aren't the best design for a harness...belts come through right behind your head and aren't spaced apart properly.
Anyway, I've been looking at different seats and different harnesses trying to figure out what to buy. I'm pretty much lost on this one. I don't know if I should go for a 4-point bolt in or if I should get on of the cheaper 3-point double buckle systems. I also don't know what seats are worth buying. I've been looking at the Sparco Torino for its price and usefulness, but the Evo is a much lighter seat. The big problem is that there aren't many locals with racing seats, and none of the local shops have any in stock that I can sit in and try out.
I would like to get a seat that holds me a lot better and a harness system well suited for autocrossing, but I don't want a setup that is not comfortable for use in a daily driver and basically renders the back seat useless.
For reference, I'm 5'11" 220lbs. I sit an average distance from the wheel with my seat upright (not trying to be ghetto and hide from bullets behind the b-pillar).
I'd appreciate it if you guys and gals could give me some suggestions. It would be especially helpful if any of you were of a comparable size and in a similar position (racing the daily driver).
Thanks in advance,
Brad
Scooby921 is offline   Reply With Quote
Old 12-15-2005, 12:52 PM   #2
pio!pio!
Member#: 4190
2008 Impreza WRX STi
I would go for a Sparco Pro2000 + a 6 pt harness
off topic a little: I've seen G-force advertise a 7 pt harness....where does that 7th go??????
pio!pio! is offline   Reply With Quote
Old 12-15-2005, 01:02 PM   #3
Scooby Freak
Member#: 40751
'94 SER
Isn't a 6 pt. a little overkill for autocrossing?
I've used a three point w/ double buckle for a couple years. It is easy to tuck away when you need the backseat. Passing the belts through the hole in the seat works fine. And you can retains the stock seatbelts for the street.
edit:
I know you are asking about seats, but I think the harness is a good inexpensive compromise. I'm getting an EVO 2 next season, but my subaru is no longer a daily driver. The EVO 2 will have more hip room than the EVO.
Scooby Freak is offline   Reply With Quote
Old 12-15-2005, 01:10 PM   #4
joltdudeuc
Member#: 6119
1999 GM6
RBP
http://www.soloracer.com/rallye4.html
best thing I ever did to help me become a faster driver. It made the course slowdown for me, and I really learned the racing line of the courses.
This is cheap, it bolts in, it retains the use of rear seat when needed by simply detaching from the front portion. I actually just sit on the harness when i'm driving daily using my regular seatbelt. I doesn't bother me at all, most of the time, I can't even feel it.
-Gagan
PS: No comment on a seat. I don't have any experience with buying racing seats. I believe that you can't run a solid back race seat in STX though. It has to be a reclinable seat I believe.
joltdudeuc is offline   Reply With Quote
Old 12-15-2005, 01:23 PM   #5
grippgoat
Member#: 62182
2005 STI
For race shells, Sparco Evo 2 and Recaro Pole Position are good choices. There's a new recaro that I forget the name of that's a bigger version of the Pole Position, as well. And I think they might have a Rev L now, too. But I've only tried the EVO2 and PP. Given your size and wanting to daily drive, anything not on the above list is probably not even worth looking at (from Recaro and Sparco, that is).
For reclining seats (what you probably want if you are daily driving it), I've got a Recaro Speed, and I like it, although it can get a bit uncomfortable about 2 hours into a road trip. I'm 6' 230lbs, though. The Sparco Torino is pretty nice. It has perhaps more agressive kidney bolstering, but much less agressive thigh bolstering.
EDIT: Oh yeah, and Speedware Motorsports is selling a limited re-release run of the Recaro SRD. It's almost identical to the speed, though.
-Mike
grippgoat is offline   Reply With Quote
Old 12-15-2005, 01:55 PM   #6
PhilC
Member#: 35190
2003 WRX STX #77
www.soloracer.com
If he's 5'11" and 220 chances are the Pro 2000 might be too narrow to be comfortable. I'm 6'0" and 190 with a 34" waist. The Pro 2000 is a comfortable but tight fit but those with larger than a 34" waist probably won't fit comfortably.
PhilC is offline   Reply With Quote
Old 12-15-2005, 03:01 PM   #7
BlkWRXWag
Member#: 31821
2015 DS WRX
Scroth Rallye 4 + stock seats = fine.
If your car is not a daily driver, then I would add a seat. Most (but not all) aftermarket seats can be a pain on an everyday basis and you lose your airbag which may or may not be important to you.
BlkWRXWag is offline   Reply With Quote
Old 12-15-2005, 03:35 PM   #8
Student Driver
Member#: 65161
2002 2.5RS, AW
I can taste teh suck
Ditto what the other guys have written. I'm 6'1" and 270lbs, and the harness works great for me with the stock seat.
Student Driver is offline   Reply With Quote
Old 12-15-2005, 03:44 PM   #9
WRX_Mundi
Member#: 33270
2004 STi
WR Blue
I guess I'll be finding out the hard way, as I just bought a used Pro 2000 to go in my STi (along with the existing Schroth 6-point harness). I'm 6'0, 190-205 pounds depending, and a 36" waist.
I have sat in a Sparco Evo and felt it was just about 1/8" too narrow (but other than that it was awesome). I've sat in someone else's (Sparco) Evo and it fit tight but not too tight. The Pro2000 is just a bit wider than the Evo, and sitting in it in the showroom and on my floor it seems to be big enough. But the proof will be in the 100-500 mile drives to events.
OK, a question since I haven't mounted it yet: do I want the sliders? I like to sit very close to the wheel, but don't normally adjust my seat unless I have a co-driver. I'm quite fine with telling some people they will have to live with the seat or just not drive my car, so that isn't a concern. They're only $50 and add a half-inch to the height, but I have the aluminum side brackets. I could put it in with the sliders, live with it for a while, then take them out later I suppose. They say they're only 3 pounds so I don't think I need to obsess over that yet.
WRX_Mundi is offline   Reply With Quote
Old 12-15-2005, 03:48 PM   #10
WRX_Mundi
Member#: 33270
2004 STi
WR Blue
Oh, and I agree with the others that if you're just concerned about staying put, try out a good harness first. With the Schroth 3" belt 6-point harness in the stock STi seat, I don't move at all. The race seat for me is about weight, some height lowering, and even more stay-put-ness. But just a harness will be a huge help (oh, and drive smooth too ).
Old 12-15-2005, 04:41 PM   #11
PhilC
Member#: 35190
2003 WRX STX #77
www.soloracer.com
If you've tried one on for size and you fit you should have no problems. I find the Pro 2000 to be very comfortable for long drives myself. I much prefer it to the stock seat for highway trips of 2 hours or so. Obviously each person is a different shape and will fit the seat differently.
We've got sliders, it makes getting in and out of the seat a lot easier. That said the sliders definitely have some play in them which I don't really like. If you grab the top of the seat you can wiggle it pretty good. Jason has Bride sliders I think and they don't have any give in them at all. I'm glad we have the extra 1/2" of height from teh sliders, ours are bottom mounted and not side mounted so height can't be changed.
Old 12-15-2005, 04:45 PM   #12
BlkWRXWag
Member#: 31821
2015 DS WRX
Also remember that most aftermarket seats are not height adjustable (at least without uninstalling them). If you are 6ft 7in and date Bridget the Midget, this could be an issue.
Old 12-15-2005, 07:04 PM   #13
pio!pio!
Member#: 4190
Im 6'2" 220 lbs...
pro2000 fits perfectly..! nice and snug but not too tight
the evo2's were a little too narrow and the pro2000 is just wide enough...plus I love the amount of leg bolster you get..you are totally snug in that seat
Old 12-15-2005, 07:21 PM   #14
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
A lot of folks have been surprised that they will fit comfortably in the regular Evo. Definitely give that a shot.
I daily drive my Miata with an Evo, it's definitely comfortable enough for dual duty.
john
Old 12-15-2005, 08:17 PM   #15
ewright
Member#: 68803
2004 WRX STi
Scooby921,
Im a decent sized guy (6 ft, 195) and fit in both the Recaro Pole Position and Recaro Porsche GT3 seat very well. I find either of these seats to be great compromises between a track seat and something which is relatively easy to get in and out of. Regardless of what seat/harness combo you decide to get, Im sure you will be very pleased with how much more you can focus on your actual driving when being held securely in position.
Ernie
ewright is offline   Reply With Quote
Old 12-15-2005, 08:35 PM   #16
REX8
Member#: 24038
Get some 02-03 seats. Much tighter fit. Work better with belts too....
Old 01-02-2006, 03:54 AM   #17
sperry
Member#: 8636
WRX, OBXT, NA Miata,
F250SD, no more SVX :(
Im 6'2" 220 lbs...
You're damn near the same size as me (I'm 6'4", 210) so it's reassuring to know that the Pro2000 is a good fit, as that's the one I was leaning towards.
Speedware has a nice measurement chart for Sparco seats BTW:
http://www.speedwaremotorsports.com/...o2000Pack.asp#
What's interesting is that the Evo/Evo2 actually has a wider hip dimension than the Pro2000, yet the Pro2000 is listed as a seat for medium to large people and the Evo/Evo2 seats are listed for medium only.
sperry is offline   Reply With Quote
Old 01-02-2006, 08:02 PM   #18
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Thanks in advance,
Brad
Brad - I ran a Corbeau FX1 and it was a good fit for me. (5'9" 220ish)
I'd recommend going w/some sliders and side mounts (Corbeau moulds in both side and bottom mount bolts with the FX1) since you'll sit lower in the car. I raced w/a Corbeau bottom mount slider (made by Wedge Engineering) in my Civic and it was too tall for me. I felt too high and my helmet would hit the headliner if I didn't sorta slouch down.
For harnesses, I run a Schroth ProFi II 4 point. I love it for my Honda but I never got it adjusted correctly in my old GF8. Not enough room to adjust it properly IMO or more likely I was too lazy to adjust it properly. Maybe the GD platform is a bit more roomy in that regard.
I got my harness from Brett @ Soloracer.com and the seat from some company in CA that JC_595 recommended. They use them when ordering seats for their vehicle simulators.
mykrrrr is offline   Reply With Quote
Old 01-02-2006, 09:25 PM   #19
davis10
Member#: 70011
I say Sparco Evo2 with a 6 pt 3' thick from SPaco as well. BTW on teh sparco website you can look at a sheet that tells you all the dimensions of their seats so you can find one that fits you better
davis10 is offline   Reply With Quote
seats and harness need help subaru fan Interior & Exterior Modification 3 12-21-2008 02:59 AM
Need suggestion on Dents and Paints evo_killer Interior & Exterior Modification 1 11-30-2004 04:52 PM
Need suggestions on making good mashed potatos. Suggestions? ChosenWon Off-Topic 36 11-27-2003 12:29 AM
Need suggestion on EVO and STI ImprezaSTIVI STi Forum Archive 107 05-19-2003 03:02 PM
Update on my ghetto paintjob...just need cage, seats and harnesses and I'm done... Sean Interior & Exterior Modification 5 11-13-2002 01:50 PM
