Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 09-09-2001, 02:25 PM   #1
Rocket
Member#: 9949
2000 Impreze RS
Default Candian Subie
Any of you guys (Canadian Owners) had a problem with your subie smelling like rotten eggs, without any mods. ????
Rocket is offline   Reply With Quote
Old 09-09-2001, 03:09 PM   #2
tulit
Member#: 338
09 STi
Yeah its the catalytic converter. Nothing much to worry about. How many km's on your car? It starts to go away after a while.
tulit is offline   Reply With Quote
Old 09-09-2001, 03:33 PM   #3
Rocket
Member#: 9949
2000 Impreze RS
I've put almost 22K on my car. The cat was changed at 5K and I've already had the O2 sensor changed. I'm using 87 AKI gas and I'm only using the big stations' fuel. Do you guys have the smell inside the car?
Old 09-09-2001, 03:35 PM   #4
Chunky_Chicken
Member#: 9782
2002 E46 M3
Laguna Seca Blue
I used to get it on my previous car (Ford Contour) and found it was its worst when I ran Shell gas. Go figure. The dealership replaced the cat twice, the O2 once, and changed the plugs. Nothing helped. Good thing all that was under warranty. Finally they changed the MAF sensor (even though it wasn't sending an CEL) and that made it go away. They said that the little venturi in the MAF was too small (moulding inclusion), and that it was causing the MAF to read too much air, making the engine run rich. Therefore giving me incomplete combustion and roasting my cats. Hence the smell.
Lots of cars get it initially, but this Ford had 80,000km.
-Pete
Chunky_Chicken is offline   Reply With Quote
Old 09-09-2001, 03:38 PM   #5
tulit
Member#: 338
09 STi
So your cat only has like 17000km on it. Give it some more time. I have about 48000 on mine, and rarely get it anymore.
All MY00/01 cars run rich by design. That may be part of the reason.
Old 09-09-2001, 05:14 PM   #6
Rocket
Member#: 9949
2000 Impreze RS
I heard somewhere that MY00 impreza don't have a MAF is that true???
Old 09-09-2001, 06:10 PM   #7
tulit
Member#: 338
09 STi
Yes its true.
It uses manifold pressure to calculate airflow.
Old 09-09-2001, 06:48 PM   #8
Rocket
Member#: 9949
2000 Impreze RS
So I guess the question of the problem being cause by the MAF is out. Anyway, today I put Sunoco 97 AKI fuel, if this doesn't make the stink go away I'm goin' to go to the Service Manager at Subaru and he'll be seeing stars. They hooked my car up to their computers and they couldn't find anything...they said everything was normal and that even though he actually smelt this thing he can't just start changing parts if nothing is wrong. He also said that he'll report the test result to subie canada (whom i've already been in touch with). By the way, that smell is actually sulphur in the fuel, this is toxic stuff guys...I read in the Toronto Sun that long exposure could cause major respiratory problems.....I still don't understand how could this stinky s h i t make it inside my car (in the cabin)????
Old 09-10-2001, 05:02 PM   #9
jetfreak
Member#: 3056
2001 Impreza 2.5RS
Blue Ridge Pearl
Rotten egg smells are usually caused by the high sulphur content in the fuel you are using. Try changing brands for a couple of tank fulls.
jetfreak is offline   Reply With Quote
Old 09-10-2001, 05:19 PM   #10
Rocket
Member#: 9949
2000 Impreze RS
Ok, which brand of fuel would you recommend. Does that have sulphur in it, cuz if it does I'm still gonna get it inside the car, may be now I won't even smell it. I just don't agree with this mentality, the smell is there if I put 87 AKI gas (which is recommeded in the subie manual). I only use Shell, Esso, Sunoco or Petro Canada to fill up since they told me not to use the other smaller stations' fuel. Now, I find out that the list of gas stations is getting smaller...com'on guys. Is this a conspiracy or what?!?!?! I see a major cover up here. Just joking. But I am not please with this whole situation? Would you guys be, put yourself in my shoes?
Old 09-11-2001, 07:44 PM   #11
jetfreak
Member#: 3056
2001 Impreza 2.5RS
Blue Ridge Pearl
I found ESSO has the worst smelling exhaust fumes. I use Shell with no foul odour emissions. Sunoco also works well in my car but I suspect that something else is your problem. Seems like you've touched on most of the other things that could be at fault. Resetting your ECU probably won't do a thing, but what have you got to loose? Sorry I could'nt be more help.
J
FS : subi garage sale all most go!!!"blitz,perrin,OEM,STI n RS" subiidude Engine/Power/Exhaust 35 03-24-2011 01:15 AM
Funny Candian humour site gmathews Vancouver Impreza Club Forum -- VIC 0 11-29-2004 10:38 PM
Candian Liberal bitchslapped for being anti-bush WHTWRX Political Playground 21 11-19-2004 05:11 PM
Looking for a Good Car Shop In Washington by Candian Border SubaruBen North West Impreza Club Forum -- NWIC 8 09-15-2003 02:54 PM
Candian bumper fog light? JP Vancouver Impreza Club Forum -- VIC 9 01-02-2002 09:46 PM
Message Board Statistics All times are GMT -4. The time now is 02:46 PM.
