Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 12-15-2005, 09:50 PM   #1
UltimateLurker
Member#: 82488
06 Lotus Exige
Storm Titanium
Default What makes a muffler go bad?
1. Rust?
2. A baffle breaking loose?
3. The packing coming apart?
Some of these after-market mufflers are little more than straight-through pipes with some perforations for fiberglass, how long will they last?
UltimateLurker is offline   Reply With Quote
Old 12-15-2005, 11:23 PM   #2
WRXRgr
Member#: 54942
2004 WRX
Yes, yes, yes.
Some will succumb to road-hazard impact, backing into high curbs, etc, and bad welds that give up. The cherry-bomb style cans can last longer or shorter, for any of the same reasons. The better ones will outlast the crappier ones. If you live in a coastal area that sees salted roads in winter, corrosion will probably be the biggest killer of exhaust parts.
WRXRgr is offline   Reply With Quote
Old 12-16-2005, 09:53 AM   #3
hikeeba
Member#: 89165
Poop Stuck Survivor
-=C=- & subari87 FOREVER!
A weak constitution and hanging out with a bad crowd will cause a muffler to go bad.
Seriously, rust may cause it to go bad, but accumulating moisture is where the rust comes from. During a short trip, you will warm up the exhaust system enought just produce moisture. When you park after a short trip, that moisture sits in your exhaust system, usually in your muffler, as it is the most restrictive section. If you have a decent commute without a lot of stopping, you heat the system up enough to evaporate the moisture out of the muffler, and it will last much longer. Moisture build up is worse in cold temps.
I have had great luck will all the factory Honda and Subaru mufflers that I have had. I also had a quality aftermarket performance cat-back system that lasted forever, too. I think you get what you pay for. I remember getting $60 lifetime-warrantied mufflers for my Accord, and after my third one, i went back to an OEM unit.
I would think a straight-through design would harbor moisture so much because it is less restrictive.
hikeeba is offline   Reply With Quote
Old 12-16-2005, 10:41 AM   #4
emorphien
Member#: 83039
2005 LegacyGT Ltd 5m
ಠ_ಠ
Salt is a big problem here in Rochester. I get my car washed multiple times throughout the winter to get salt off the exhaust, but a lot of people wait until the end of the winter which gives that salt time to chew away at exhaust bits.
emorphien is offline   Reply With Quote
Old 12-16-2005, 11:07 AM   #5
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
The bearings just wear out over time. High heat and such
Old 12-16-2005, 11:11 AM   #6
99ways2die
Member#: 96269
... blond with
long legs
Your muffler has bearings?
99ways2die is offline   Reply With Quote
Old 12-16-2005, 11:11 AM   #7
PhatMatt
Member#: 17631
2002 Protege5
Hanging out with a bad crowd? Drinking beer at an early age?
*not allowing for the condensation to burn off inside between start up and shut down.
PhatMatt is offline   Reply With Quote
Old 12-16-2005, 11:20 AM   #8
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
Mufflers don't have bearings.
This is what happens when you fall asleep at the mouse.
conker69 is offline   Reply With Quote
Old 12-16-2005, 11:23 AM   #9
emorphien
Member#: 83039
ಠ_ಠ
Yeah, mufflers don't have bearings just like blinkers don't have blinker fluid. Come on get with the program.
Old 12-16-2005, 11:29 AM   #10
conker69
Member#: 59692
WRB-Gold
That reminds me...I need a new hood scoop plug and some more turbo boost fluid.
Old 12-16-2005, 11:29 AM   #11
2fas4u
Member#: 90691
2005 STI / 2009 STI
Hey!! I want muffler with bearings....
2fas4u is offline   Reply With Quote
Old 12-16-2005, 12:14 PM   #12
RichardM
Member#: 39915
2007 Legacy GT
Some mufflers DO really have bearings. :-) Well, the mufflers are mounted on bearings. The exhaust system of a very large engine like those used for 2500 kVA generators (65 to 70 liter engines) expand as they heat up. So the mufflers are mounted on bearings to allow them to expand.
Richard
RichardM is offline   Reply With Quote
Old 12-16-2005, 12:25 PM   #13
KCramer
Member#: 3624
'02 Monster Bugeye
yes...they do!
KCramer is offline   Reply With Quote
Old 12-16-2005, 12:46 PM   #14
avatarr
Member#: 14010
'04 APS-ified STi
TopSpeed Tuned - Black
Any high power diesel generator in-the-know person knows you don't refer to generators in kVA rating. 2000kW (2MW) FTW!
-Jason
avatarr is offline   Reply With Quote
Old 12-16-2005, 01:39 PM   #15
Pete Holt
Member#: 12
2014 Evo GSR
Wicked White
Ah yes, muffler bearings and blinker fluid. This season, also be sure to change the oil in your tires and rotate your radiator.
Pete Holt is offline   Reply With Quote
Old 12-16-2005, 01:40 PM   #16
USF97J4x4
Member#: 83035
If you're rotator splint gets water-logged, some rust will form and then your muffler is as good as garbage
USF97J4x4 is offline   Reply With Quote
Old 12-16-2005, 01:47 PM   #17
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
My experience
The previous owner of a 86 Mazda MX-6 I owned went up skiing a LOT. As a result, a lot of the underside was rusted, which ate up the cat back and muffler. I eventually had to replace both because rust had eaten through the layers of the muffler and holes appeared. The cat back pipe also rusted to a point where a hole was ripped open by the exaust.
My relative's Audi had a cat that deteriorated and was shot down the exhaust until it got trapped in the baffled muffler which caused it to massively restrict and make lots of annoying noises. (Like cotton in a pipe)
My Civic has lived in the garage at night all its life and I never went to the snow with it. The muffler, although aged, is still in great shape. I did scrap up the mounting bolt of the tip going down a stupid parking lot exit.
chimchimm5 is offline   Reply With Quote
Old 12-16-2005, 02:00 PM   #18
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Mufflers don't have bearings? What about these?
Old 12-16-2005, 02:08 PM   #19
supersport
Member#: 70337
2005 STi
What's that on your hood?
If your piston return springs go bad then it can cause your muffler to rust.
supersport is offline   Reply With Quote
Old 12-16-2005, 02:43 PM   #20
RichardM
Member#: 39915
2007 Legacy GT
-Jason
Thank goodness I don't have to know about generators. After all, specifiying them is how I make my living.
Richard P.E. in electrical power for facility design.
Old 12-16-2005, 04:30 PM   #21
bprime
Member#: 98695
1996 200sx se-r
black
that's why I use synthetic blinker fluid and carbon fiber plated turbo wires
no bad bearing for never!!!
bprime is offline   Reply With Quote
Old 12-16-2005, 04:43 PM   #22
dvang
Member#: 84188
05 legacy
caravan full of kids now
just make sure to change the belts on your muffler and turbo and you shouldnt have any problems.
dvang is offline   Reply With Quote
Old 12-16-2005, 05:56 PM   #23
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Yeah, but if you use direct injection to the catalytic converter, then you can often exceed advance timings on the compression ratio; but that's easily fixed by adding a BOV before the MAF sensor but after the 2nd O2 sensor.
Old 12-16-2005, 07:10 PM   #24
hikeeba
Member#: 89165
Poop Stuck Survivor
Wow, it didn't take long for this thread to start circling the drain.
I did quite a bit of research on this today, and I can confirm that excessice exposure to salt and moisture are leading causes of a muffler going bad. Another cause could be an unhappy trunk monkey, trying to get back at you for ill treatment. Beware, trunk monkeys can be very vengeful.
Old 12-17-2005, 03:27 AM   #25
RUrunning
Member#: 68758
15 STi
LE
drugs... and porn
RUrunning is offline   Reply With Quote
Oxygen Sensor - What causes them to go bad? Carlito2002WGN Newbies & FAQs 9 04-28-2013 11:09 AM
Actual question -- What makes Subaru paint so bad? WRblueX_Guy Interior & Exterior Modification 8 02-28-2007 06:49 PM
What causes synchros to go bad? wrxbert Transmission (AT/MT) & Driveline 40 12-08-2005 08:34 AM
What Makes a Muffler Cost/Worth $400-$565 ??? HerculesPeanut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-17-2003 12:04 PM
What defines a good or bad muffler ? DEVO Newbies & FAQs 3 10-24-2000 12:14 AM
