Old 12-16-2005, 04:02 PM   #1
Starkiller
Member#: 82741
2007 350Z Silver
Default How do you check if you need to align bore your block?
Bought blown motor cheap.
Teardown revealed bent crankshaft (.014).
Refer to thread title.
Starkiller is offline   Reply With Quote
Old 12-16-2005, 04:47 PM   #2
dru_hill
Member#: 67661
2004 WRX sedan
I think you answered your own question. If you have a bent crankshaft, you should AT LEAST check the alignment. I would bet a shiny nickel that youll need some kind of machine work on the bottom end if you are 0.014 out of spec. You'd be pretty pissed off if you built the whole motor and then found out you need an align bore.
dru_hill is offline   Reply With Quote
Old 12-16-2005, 05:49 PM   #3
ncarn8
Member#: 71419
if its out youll notice out of spec oil clearances. theres no free lunches man so the money you saved really needs to be spent on getting it thouroughly checked out. That is if you want it to be problem free for a decent time. Id also want to crack test it, and have a close look at the deck warpage and condition of bores.
you cant just whack a new crank or a machined one in and hope for the best. drop it off at a truted experienced machine shop and have them do what they do best.
ncarn8 is offline   Reply With Quote
Old 12-16-2005, 08:08 PM   #4
Starkiller
Member#: 82741
2007 350Z Silver
I've already checked for deck warpage and the bores came out ok.
So really, the only way I'm ever going to know if I need to bore out the mains is by mounting a new crank w/bearings and checking with plastigage?
Old 12-16-2005, 11:13 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if it is a 205...make a boat anchor out of it and get a 257 shortblock and go from there.
the open deck block is, IMO, junk waithing to blow up anyway
Old 12-17-2005, 01:17 AM   #6
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Why do you feel that way? I've seen lots of (key here ) well tuned 205s put down 300whp with ease. Not sure I'd bother building a stock one, but that still doesn't mean they're junk.
jamesfacts is offline   Reply With Quote
Old 12-17-2005, 10:17 AM   #7
Starkiller
Member#: 82741
2007 350Z Silver
Actually, the block is a 257. Its just more people view the 2L forums then the 2.5 forum.
Old 12-17-2005, 10:18 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
drive an '06 wrx just once and then tell me you don't want a 2.5 instead of a 2.0.
Old 12-17-2005, 10:45 AM   #9
JRSCCivic98
Member#: 67080
Ok, splitting hairs here, but this statement has nothing to do with whether or not a 2.5L is stout because of it's semi-closed deck. It has to do with it's displacement. So this statement and the previous one don't exactly go hand in hand.
JRSCCivic98 is offline   Reply With Quote
Old 12-17-2005, 10:53 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
....no they DO go hand in hand...ya just have to see the connection
How do I know if I need new brake pads? Sunny06STi Newbies & FAQs 14 02-15-2010 04:20 PM
How do i check if my shock/struts are going bad? Hyelude Newbies & FAQs 1 07-23-2009 05:14 PM
How do I check if my rings have seated? big67 Built Motor Discussion 6 04-16-2009 11:00 PM
Steering bushings....what do they do and how do you know if you need them replaced? kaisersouse Brakes, Steering & Suspension 4 01-11-2006 11:51 AM
how do i check if i have any warning points? rich728 Newbies & FAQs 5 09-17-2003 09:55 PM
