Old 09-09-2001, 06:06 PM   #1
slide
Member#: 1130
2013 STI Hatch
Default Looking for rear pillow ball mounts
I want to buy rear camber plates. Or even just solid mounts. Rears only for a 95 wagon. Anyone have any for sale?
925-957-0217. .
Thanks
slide is online now   Reply With Quote
Old 09-11-2001, 09:25 PM   #2
slide
Member#: 1130
2013 STI Hatch
bump. Any body?
Old 09-12-2001, 08:17 PM   #3
SYMS GT
Member#: 427
'91 SS Legacy EJ257
DOHC/18g/FMIC/V.8 6spd
Try iSR, SPD, or COBB. Pretty much all of the Impreza parts cross over from what I can see/done. Just double check with them they should know.
-Matt
SYMS GT is offline   Reply With Quote
Old 09-13-2001, 01:04 PM   #4
BG5
Member#: 695
But I thought the Legacy had different rear mounts than the Impreza (single piece instead of two piece and somewhat different hole configuration). Subie Gal had this problem a while back and IIRC DMS-USA had the solution.
Don't know any cheap options (bar ordering from Japan)...
Otherwise the ghetto solution is to get some new or used ones and fill all the spaces in the rubber with windshield or rubber-repair polyurethane of a hard durometer. 3M makes a cartridge of the stuff that some people like to use for around $10.
If you really want to adjust camber, look for camber bolts from specprod.com (they make the Whiteline bolts)
BG5 is offline   Reply With Quote
Old 09-13-2001, 01:22 PM   #5
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Thing number one: PBMs are going to be noisy as HECK in a wagon, take it from a guy who had 'em. Having said that, Tein and Cusco both do stand alone PBMs. Hook up with Imprezer, or Dale at Teague's Auto. Either one of those guys should have answers for you.
Legacies do indeed have different rear top mounts, but the WRX uses the same mount. So with the development of the aftermarket for that car, you will have more options than you would have had six months ago.
Good luck,
Kevin
gtguy is offline   Reply With Quote
Old 09-13-2001, 07:24 PM   #6
slide
Member#: 1130
2013 STI Hatch
They have been in production for years. Its different than the impreza, bolt spacing. I just wanted to see if anyone had a set they wanted to sell.
Camber plates, and rear Pillow Ball mounts stubaru88 Private 'Wanted' Classifieds 6 05-21-2007 11:53 PM
WTB: pillow ball mounts for GC zroom tsuchiya Private 'Wanted' Classifieds 0 06-26-2006 11:30 AM
STi strut tops vs. pillow ball mounts for coil-overs pbnj9786 Brakes, Steering & Suspension 9 08-07-2001 04:14 PM
What is the going rate for TEIN front and rear pillow ball mounts? Robmat Brakes, Steering & Suspension 0 07-19-2001 05:59 PM
TIEN rear pillow ball mounts JC SPORTS Technical Forum Archive 8 06-09-2000 02:03 AM
