#1 |
Member#: 88254
TXIC
flashed my ap for the second time since i got it. Said my battery was low. I made sure it was fully charged. No my car wont start and it wont go into test mode. WHAT DO I DO? Please help me guys
#2 |
Member#: 69659
South East
Vehicle:07 BMW 335 12.6 @ 111.1 |
Try flashing back to stock.
#3 |
Member#: 88254
TXIC
i just did that and it let me. I drove it around, everything seems normal. Now what? How do u tell if the battery has full charge? Should i drive it around for a few minutes, let it sit in place running? I dont want to mess up flashing to stage 2 again.
#4 |
Member#: 88254
TXIC
i havent put the connectors back on to even see if it goes into test mode. Im too scared. I flashed to stage 1 last night with no problem, TBE is on and i want to go to stage 2, but is it ok now?
#5 |
Member#: 82311
SCIC
Vehicle:2006 Evolution IX Electric Blue |
I put jumper cables on my battery to make sure it had enough juice.
Well if you fry it that is what warenty is for. |
#6 |
Member#: 88254
TXIC
i wouldnt thing warranty would cover a fried ecu. But car is running right now, it goes into test mode once again. And the accessport is unmarried
#7 |
Member#: 80663
SWIC
Vehicle:1997 Outback |
You don't need to keep re-flashing your base map. That is what the realtime map is for. Flash it once, then leave it alone. Just make changes via realtime.
#8 | |
Member#: 88254
TXIC
#9 |
Member#: 88254
TXIC
so basically to my knowledge, since cobbs site doesnt explain too much, I need to flash the base map stage 2 then i need to flash the real time stage 2 map to have the both running? Is that correct? Or do i flash the base map stage 2 and switch my realtime back and forth between others like valet and antitheft?
#10 |
Member#: 54598
South East
Vehicle:2004 WRX Sedan WR Blue Pearl #68 STX |
If you have a tbe (at least a downpipe) then flash the stage 2 basemap. That will be better than runnning the stage 1 basemap with the stage 2 realtime map over it.
#11 |
Member#: 86997
BAIC
Vehicle:2002 Impreza WRX Silver |
ok, heres what I just recently learned:
BASE MAP: use this for the map you want to use all the time when driving around and whatnot (stage 2, or protune) REAL TIME MAP: use this for the race maps and stuff. it is a map that is loaded onto the ECU instead of actually reflashing the memory. Think of it as a temporary override for the base map. this is all done because the ECU can only be reflashed about 100 times |
#12 | |
Member#: 55011
Vehicle:2002 |
#13 |
Member#: 54598
South East
You don't need to run the stage 2 realtime map over the basemap. It won't make any difference, you can if you want to, but it won't do anything.
Realtime maps are there to make quick flashes mostly, such as switching to valet mode, economy mode, anti-theft mode, stx legal mode, etc.. Use the basemap for what you want to run as your everyday map. If you do happen to flash to a different realtime map than your basemap, than you can load your current basemap's realtime map to get you back to the original basemap parameters. Example-- Have stage 2 basemap--> go to valet mode realtime map, decide to go back to stage 2--> flash the stage 2 realtime map or reset ecu. I know it all is a little confusing. Just remember the basemap will be loaded on the ecu even if power is disconnected, realtime map will go away once power is disconnected. The 100 reflash limit is really just a safety precaution, I don't believe anyone has ever reflashed there ecu too many times. Only the basemaps affect that imagenary count. |
#14 |
Member#: 88254
TXIC
alright cool. But what maps would be used for race? Not really much on cobbs site except stage 1, 2, 2.5, and something about hittin target boost. So im guessin that doesnt apply to me. Im goin to get somethin to eat to make sure the battery is fully charged and im gonna get this thing goin. Will it make a difference if i just flash to base stage 2, or should i also run realtime stage 2 with that? Not really interested in all the other stuff
#15 |
Member#: 88254
TXIC
thanks boundy, ignore the last statement by me. u must have been typin while i was
#16 | |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
Its NOT A LIMIT. The 100 number is a minimum rating. More than likely, you could flash it 1000 times. There are people on this who are well into the 300+ flashes. |
#17 |
Member#: 54598
South East
^^^ That is what I was trying to say.
#18 |
Member#: 80663
SWIC
As I understand, unless you are doing some extensive protuning or streettuning as actually chaning basemap parameters, it does not matter what basemap you have...just run the appropriate realtime.
#19 |
Member#: 85413
Vehicle:2004 WRX silver |
ok, well how does the ecu know what the stock map was if you replace the basemap with stg 2?? I only ask b/c i might have to revert back to stock for dealer visits
#20 |
Member#: 11411
SWIC
How does the ecu know what the stock map was? I dont quite understand from that choice of words but it goes back to stock by you personally flashing a stock map from your AP. It may not be your particular stock map (as there are multiple versions for different years and build dates) but it is "stock".
#21 | |
Member#: 50699
TXIC
Vehicle:2004 WRX Platinum Silver |
real time is like ram. its not hard written, needs power to remember base map is like rom. no power needed for tha cd to remember what is written on it. another anology real time = vcr clock (back to 12:00) base map = vcr tape (tape does no lose data regardless of power loss) Joe |
#22 |
Member#: 85413
Thats a great way of looking at it, thanks joe. CBoldman, so the ap does have a stock map that i can revert back to incase i need to. Ok that was my question. I didnt know if the stock map was pre-programed into the ap, or it had to download it from the car. Thast good to know that i can always do that if need be. Thanks!!!!
#23 | |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
#24 | |
Member#: 50699
TXIC
for instance, you flash the valet mode as your base. then put the stage 2 real time on top. well for now you are running stage 2 (understand some maps are better for running at a stage 2 level). now lets say you battery dies, without touching your ap, you will be in valet mode again till you put a real time map on it. Joe ride 5000: start your own thread in regards to your question. I am sure a search will yeild many results as soem answers have already been given to you on tari and other boards i am sure. |
#25 | |
Member#: 32792
NESIC
![]() i don't remember you starting this thread, i didn't bring up the flash limit, and i surely didn't ask you any questions. |
| Thread Tools | |
| Display Modes | |
| ECU wiring- please help | dub c | Electrical & Lighting | 1 | 12-05-2007 06:04 PM |
| Ecu wiring- please help! | dub c | Factory 2.0L Turbo Powertrain | 0 | 12-05-2007 03:13 PM |
| AP Map loading problems. Please help. | dj_booduh | AccessPort | 5 | 06-23-2006 01:31 AM |
| ? about AP, Intakes, & Exhausts Please Help!!! | RonBang | Engine Management & Tuning | 2 | 07-10-2005 01:30 PM |
| problem with link ecu. someone please help! | STi2002WRX | Factory 2.0L Turbo Powertrain | 2 | 10-16-2002 05:04 AM |
