Old 12-17-2005, 03:31 PM   #1
Deus ex Machina
Member#: 79815
06 Mazda 6S
Default My car just threw a PO136...
PO136- Rear O2 sensor circuit faliure.
My car is catless.
I have a 50/50 BOV/Reciculation valve. Could the slight running rich between shifts "damage" the O2 sensor over time?
Another theory; at first I tried to do the resistor fix to the rear sensor, but ended up using the mechanical fix instead. So the harness was hacked up hardcore and then put back together. This was a good 10k miles ago, and it worked just fine until now..
So should I go buy a new rear sensor and leave it at that, or try to take it out and repatch the wires? There is a lot of salt and snow around here and I figure the combination of the two got to my craptacular patch job
Off Topic: Would it be OK to switch from mobil 1 synthetic to the mobil 1 5000 mile version for this one oil change? I'll probably switch back to synthetic before autocross season, but I have a really cheap crate of the regular stuff sitting here.
Thanks!
Alex
Deus ex Machina is offline   Reply With Quote
Old 12-19-2005, 01:29 AM   #2
Deus ex Machina
Member#: 79815
06 Mazda 6S
bump.
It turned off for part of today and came back on at night. Oh well
Old 12-19-2005, 07:53 AM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
for the sensor, I would get under there and take a look.
for the oil, you should be fine - however, since M-1 only costs around $5 a qt, you really aren't saving a whole lot of $ by switching temporarily...
My ETX14 battery install. AKA: my car just lost 20lbs! djerickd Electrical & Lighting 36 03-14-2007 07:04 PM
car just threw a CEL for the first time haw4747 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-09-2007 04:28 PM
My kitty just threw up... :*-( Jard Off-Topic 39 10-20-2005 04:17 AM
My cat just threw up wcbjr Off-Topic 19 09-13-2004 07:46 PM
nicer pics of my car! just waxed. bratmantlz Member's Car Gallery 10 05-11-2001 06:43 AM
