Old 12-18-2005, 01:57 AM   #1
JNUTZ
Member#: 90132
2003 WRX
Rally Blue
Default p0138?
So I had my CEL pulled today and got
P0138 EGO Sensor Circuit High Voltage (Bank 1 Sensor 2)
Can anyone tell me why I'm getting this? I am running cat less and had the cat deficiency code but then put in the mechanical cel fix, and now I'm getting this one.
Any help would be great, I searched it but can't find an answer on what it actually means and how to fix. Thanks
JNUTZ is offline   Reply With Quote
Old 12-19-2005, 01:17 AM   #2
JNUTZ
Member#: 90132
2003 WRX
Rally Blue
anyone?
Old 12-20-2005, 11:29 PM   #3
JNUTZ
Member#: 90132
2003 WRX
Rally Blue
still looking for help!
Old 12-20-2005, 11:32 PM   #4
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Rear o2 that failed? harder on gas lately?
Subaru code is P0138 - Rear O2 Sensor Circuit High Voltage
Robin2 is offline   Reply With Quote
Old 12-21-2005, 01:26 AM   #5
JNUTZ
Member#: 90132
2003 WRX
Rally Blue
well, gas milage is normal, I mean winter gas and running stage 2+ utec. with headers and moddified injectors, But if I change the o2 sensor is it gonna happen again? or will that clear it up?
Old 12-22-2005, 10:21 PM   #6
JNUTZ
Member#: 90132
2003 WRX
Rally Blue
Subby Gurus where are you
Old 12-23-2005, 01:40 PM   #7
hondaeater69
Member#: 60324
hey got your email. . .
the P0138 is a rear 02 sensor code, nothing to worry about. . .that sensor only monitors emissions and won't mess with fueling. If you don't get the cat eff code anymore, this may mean the sensor is going bad, or i would imagine it may mean you didn't do the mechanical fix properly.
What confuses me is that you posted EGO something. . .there is another code out there for EGT circuit too high, which will require an electrical resistor fix.
Make sure this is indeed the rear 02 sensor code. Double check your work to make sure you did the mechanical fix properly. If you did and you still get the code, i wouldn't really worry about it. I don't even have my rear 02 sensor plugged in!!
Please note i am NOT a cel fix expert, as a matter of fact i've NEVER done one, just read about it. I use AP + ST and this software automatically takes care of all EGt and REAR 02 sensor codes and elminiates them from rising their ugly heads without the need for CEL fixes.
HTH's!
Old 12-23-2005, 07:03 PM   #8
JNUTZ
Member#: 90132
2003 WRX
Rally Blue
Thanks for your help. I'll check the fix. Could be I just didn't drill it out enough
Old 04-12-2006, 01:36 AM   #9
hatchy
Member#: 36852
2004 STI
I have the same problem, replaced the rear sensor, didnt fix it.
hatchy is offline   Reply With Quote
ECU Error code P0138 questions. Malcolm_McAvoy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-22-2010 07:24 PM
P0139 P0138 Jim2752 Off-Topic 16 05-15-2008 12:52 AM
CEL p0138 and p0420 HELP ME! fastlanerex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2007 05:19 PM
Anyone know what a p0138 really means? OvrClkdPmp Engine Management & Tuning 5 02-16-2005 12:23 PM
ECU Trouble Code P0138 Kevin Thomas Normally Aspirated Powertrain 2 04-03-2002 03:04 PM
