#201 |
Member#: 125304
fuji how come this is in the conversion thread? I like your head story but I thought it was in the built motor thread?
#202 |
Member#: 53558
NWIC
Vehicle:2002 WRX Wagon Silver |
Requesting a pic comparison: V8 Spec C compared to a USDM EJ205. If it's even possible. If not, no worries.
#203 |
Member#: 153412
Vehicle:1998 Impreza wrxRS Black |
#204 |
Member#: 53558
NWIC
#205 |
Member#: 33782
Vehicle:96 bastard child search FIRST, then PM!!! |
^^yes they were. However I think he meant first subaru boxer.
#206 | |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
the STi heads I'm porting are done and thats the Double-D thread. Very interesting finds because I have all these heads on hand or accessible. |
#207 |
Member#: 3687
The V8 Spec C are not any bigger than the Big Ports them selves. Have the Spec C heads measured via CNC machine and you can port the USDM EJ205 heads just like them.
#208 | |
Member#: 53558
NWIC
Depends on if the I&M ODBII machines in the Southern Oregon area can read the JDM ECU, and if they can't if I can do sniffer test instead. If that's a no-no, then I'll be limited to running EJ207 bottom with EJ205 ported heads on top anyway.Having the EJ207 longblock would be nice, since i'm going to be getting an 2.5RS for a daily while my WRX is down. Once the WRX has a new engine, transmission, driveshafts, hubs, brakes, suspension, etc., everything leftover from the WRX will be going onto the 2.5RS. ![]() |
#209 |
Member#: 79825
VIC
Vehicle:2000 Impreza 2.5 RS White body + carbon hood |
stock eg33 heads for visual reference/ comparison
#210 |
Member#: 3687
now that's interesting. Sharing the phase1 EJ22E intake port inlet shape with EJ20 runner route and combustion chamber
#211 |
Member#: 3687
#212 |
Member#: 3687
B25 exhaust
![]() S20/S20V/W20/D25/V25B/W25 ![]() Updated exhaust port listing^^^^^ Last edited by FuJi K; 05-14-2011 at 10:19 AM. |
#213 |
Member#: 3687
#214 |
Member#: 255714
Vehicle:2005 STi psm 20g 11.5 or bust! |
Sticky this!
#215 |
Member#: 135850
JDM 2006 Legacy GT heads, EJ20Y 2L motor, Quad AVCS
#216 |
Member#: 3687
ah hA! I've seen that intake port before. Subaru still uses that on the '06 Leggy in Japan eh.. the arch from the inlet to the valve follows the big ports on that style port. Thanks for the pics!
#217 |
Member#: 135850
No probs, any suggestions on improving them would be appreciated. I'll be pulling it apart in the coming weeks, trying to measure the combustion chamber, going oversize valves and a stroker blah blah. May as well clean the heads up if I can while I'm there
#218 |
Member#: 3687
you can shape them to look very close to the big ports.
#219 |
Member#: 135850
Any more pics / info on the W25 head? I might have found a set, curious to see what the ports are like.
#220 |
Member#: 296804
do you have any pictures about ej204 legacy jdm heads?
#221 |
Member#: 33782
I have a set of 2.0L dual AVCS heads sititng in my living room (don't ask
)I however am wondering if the combustion chamber is the same. Mine cam with ports already plugged for what looks like direct injection. I also have one of your pistons So did you want to get a forged set made or...? |
#222 |
Member#: 297130
NWIC
Vehicle:1997 impreza L custom gold/copper |
heres some eg33 shots i have
this is the exhaust ports ported vrs ported the green circle on the right port is the size of the stock exhaust gasket ![]() heres stock intake port ![]() here s a partially ported intake port ![]() |
#223 |
Member#: 71287
South East
Vehicle:2002 WRX + 2004 STi + 2009 STi/WRBx2 and OBP |
...and subscribed!!!
#224 |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
.... also subscribing
#225 |
Member#: 3687
I thought this was interesting. So we got a Forester engine.
We as in U.S.A.JDM SG9 EJ255 with B25 heads ![]() ![]() |
| Thread Tools | |
| Display Modes | |
| head porting and arp head studs..... | ejsportcom | Built Motor Discussion | 6 | 03-24-2006 12:05 PM |
| IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold | BLUETURBOWRX | Private 'For Sale' Classifieds | 20 | 03-06-2005 06:19 PM |
| IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. | BLUETURBOWRX | Mid West Subaru Owners Club Forum -- MWSOC | 14 | 02-23-2005 09:47 PM |
| throttle body & head porting? | JST | Normally Aspirated with bolt-on Forced Induction Powertrain | 5 | 07-23-2002 08:24 AM |
