#1 |
Member#: 61371
Vehicle:2002 BMW 330ci Alpine White |
i just switched over to a GT32 and no longer need the coolant reservoir for the turbo. I figured I can just loop the feed and return hose from the radiator back into each other, but what about the two lines that run to the head? Anyone have to do this before and know what needs to be done to eliminate this reservoir? TIA.
-Joey
#2 |
Member#: 6598
Vehicle:2012 Mazdaspeed3 Crystal White Pearl |
That upper tank also feeds your overflow tank. I might be easier to leave it and just bypass the turbo.
#3 |
Member#: 61371
it would just be a lot easier for me to remove it all together because im wanting to route an intercooler pipe through there. i was thinking i could just run the two that feed the head back into each other, run the feed and return to the radiator into each other and id be good.
| Thread Tools | |
| Display Modes | |
| Top coolant reservoir - remove for oil only turbos? | Bad Noodle | Factory 2.5L Turbo Powertrain | 17 | 09-03-2011 08:43 PM |
| need upper coolant line for turbo | t4nk | AKIC Private Classifieds | 0 | 09-13-2008 04:53 PM |
| Remove Cap on Turbo Coolant Reservoir? (Yes I suck) | proletariandan | Factory 2.0L Turbo Powertrain | 22 | 09-10-2007 02:10 PM |
| Oil/Coolant connections for turbo | SCOOBER | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 04-19-2003 12:08 PM |
| Coolant source for turbo | Boostup! | Normally Aspirated with bolt-on Forced Induction Powertrain | 27 | 05-10-2002 08:08 AM |
