Old 12-18-2005, 06:32 PM   #1
qoncept
Member#: 44762
2013 BRZ
Default HVAC problems
About 6 months ago I was messing around by my HVAC, trying to find a place to relocate my stereo. Ever since, the fan will only work on level 4. On 1, 2 and 3, when the AC is turned on, the AC compressor will start, but the fan won't blow. I looked through the wiring diagrams, and I think I have the problem narrowed down to the resistors you can see in the diagram below. Problem is, I don't have a clue where it is and can't find it nosing around inside the dash. Does anyone have a clue? Also, if anyone has another idea of what might be the problem, that'd help, too. Thanks!
qoncept is offline   Reply With Quote
Old 12-18-2005, 07:17 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Moved this to the proper forum.
Your problem is almost certainly with the resistor assembly. Either it's bad or disconnected.
The resistor module is located at the bottom of the HVAC unit under the passenger footwell. Look under there, there are two connectors one of which is the blower motor. The other one is the resistor module. You can disconnect the module and remove it, and visually inspect it as well as test it with an ohmeter. It isn't a very expensive part to replace. If the module is ok, check around the HVAC controls for an unplugged connector or damaged wires.
Old 12-19-2005, 03:58 PM   #3
qoncept
Member#: 44762
2013 BRZ
Awesome, thanks. I just tested the blower resistor and it seems to be bad.
HVAC problem sum0325 Electrical & Lighting 8 02-15-2009 06:33 PM
HVAC problems Matt Mid Atlantic Impreza Club -- MAIC 0 02-23-2008 09:44 PM
HVAC problems! SubaruImpreza_power Service & Maintenance 6 01-29-2004 12:28 AM
HVAC Problem 98LegacyGT Legacy Forum 4 12-10-2003 04:19 PM
HVAC Problem 98LegacyGT Electrical & Lighting 2 12-10-2003 11:17 AM
