#1 |
Member#: 70037
Vehicle:2002 Outback Sport Green |
Other than changing oil and checking tire pressure, what sorts of checks do folks do routinely? How often?
I am trying to take care of things myself except for the 30K services, and I want to make sure I am covering the important things. TIA
#2 |
Member#: 25119
BAIC
Vehicle:2005 Impreza WRX STi Silver |
go to http://www.licmotorsports.com/306090k.htm and do all those maintenance schedule. Just change the oil every 5k with synethic, 3k with regular engine oil, check tire pressure, check fluids and leaks, and hoses everytime u change your oil. As long as you change the oil..the engine should be running great. The timing belt, sparks plug, and all that o ther stuff can be changed in the schedule mainteance schedule.
#3 |
Member#: 68758
SCIC
Vehicle:04 STi R.I.P. AEROSIM |
30k service go for new spark plugs, tranny/diff fluid, brake fluid, engine oil, clean your air filter, check your brake pads and tire wear, and you could ambitious and flush your radiator and check your timing/drive belts, but i'd just stick to the basics for now.
| Thread Tools | |
| Display Modes | |
| Garage Near Nampa For Routine Maintenance | OnTheGas | North West Impreza Club Forum -- NWIC | 0 | 11-19-2005 12:15 AM |
| NASIOC.com will be down for routine maintenance from 4:30 - 4:40am EST | 24 | Off-Topic | 3 | 10-07-2005 04:57 AM |
| 96 Legacy Outback - Routine maintenance parts | rogue | Legacy Forum | 6 | 03-08-2004 03:00 PM |
| question on routine maintenance? | spike | Service & Maintenance | 4 | 04-27-2003 01:02 PM |
| Subaru routine maintenance ???? | WRX-1977 | New England Impreza Club Forum -- NESIC | 3 | 12-19-2000 09:21 PM |
