Notices
Old 12-18-2005, 10:20 PM   #1
myver8
Member#: 100817
2004 subaru
Default wrx heat problem
ok guy's my mothers heats acting up on her 04 wrx (out of warrenty) works fine when your driveing but as soon as you stop in like 20 sec of the motor idleing the air coming out of the vents is cool (70) as soon as you start driving 5-8 sec it's back to normal this all happens when the car is completely warm and it's about 35 now so it's not to so cold that it going to mess with how well the heater works
myver8 is offline   Reply With Quote
Old 12-18-2005, 10:24 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
First thing is to check the coolant level. If it's low you may get insufficient heat. If it does turn out to be low, look for leaks because it really shouldn't have lost that much coolant.
Other possibilities are a blocked heater core (unlikely in a low mileage car), air in the system, or a failing water pump (again unlikely but not impossible).
05 WRX Heated Seat Problem? STIRallyFan8766 Electrical & Lighting 2 02-08-2010 11:57 PM
05 wrx heated seat problem Shaka_G Electrical & Lighting 4 11-25-2008 10:58 PM
Stange Coolant/heating problem ImprezaGuy Normally Aspirated Powertrain 4 08-14-2002 01:57 AM
Over Heating Problem akuhner Normally Aspirated Powertrain 24 12-28-2000 06:45 AM
Heat Problem... besides on 4 2.5RSt'd General Forum Archive 4 12-07-2000 06:58 AM
