#1 |
Member#: 92210
Vehicle:02 WRX Blueee |
My rear defrost isnt working.
Press button and I hear a click, but the light does not come on, and the rear windshield does not defrost/defog ![]()
#2 |
Member#: 99777
International
Usually when there are gaps in the lines that line of defrost element wont work. But this sounds like it is at the switch end.
Check the fuse first, if that is okay get a $2.99 switch from Radio Shack that has a light, wire it up and see if tht works. If it does you can get a new switch from one of the OEM Vendors here. If it doesn't it's probably more involved and I can't really help you. You may also want to check out where the wiring connects to the rear window. But again it sounds like your problem is on the switch end. |
#3 |
Member#: 101240
Vehicle:2005 Impreza RS Crystal Grey |
on the topic of rear defrost, i was just curious to know if when i turn it on, does it over a certain time frame, automatically shut off??
#4 | |
Member#: 90387
Vehicle:05 stg 2 wrx RIP wrb |
#5 | |
Member#: 82767
NWIC
yes as stated the rear defrost automatically shuts off after 15mins also shuts off when ignition switch is turned to ACC or LOCK position ![]() Happy Holidays!! ![]() Jamie Thomas [email]Jamie at chaplins.com ![]() *************************** www.subiegal.com |
#6 | |
Member#: 64447
| Thread Tools | |
| Display Modes | |
| Rear defroster and Wiper defroster install with Remote Start | rockwvu | Car Audio, Video & Security | 2 | 11-24-2004 01:23 PM |
| rear decal and rear defrost problems? | Max Umbarger | Interior & Exterior Modification | 3 | 04-30-2004 03:38 AM |
| rear defroster problem on WRX? | twlai | Factory 2.0L Turbo Powertrain | 1 | 12-10-2001 03:08 PM |
| ('93-'01) 2 wires of my rear defroster is not working. | Snoopy | Impreza Forum | 3 | 07-05-2001 05:48 PM |
| rear defroster killing my FM reception | Keith | Car Audio, Video & Security | 4 | 10-26-2000 12:56 AM |
