Old 12-19-2005, 11:47 AM   #1
VWGrk1
Member#: 57882
2004 WRX
Default SMC Users- What Size Nozzle Are You Running?
I am running a stage 4 setup w/ an 18G. I have the SMC kit ready to go, but I think that the nozzle that I am using is too big. My memory might be off, but the nozzle they usually send with the kit is a HAGO 7 or .07.
For some reason, I asked for a HAGO 10 or .10. With this nozzle, I think that I am spraying way, way too much booze and flooding the motor. I had the car on a dyno and the darn thing was mis-firing like mad. The tuner was Jorge, a well-known expert, so I highly doubt that there was something wrong with the tuning procedure.
So, what nozzle are you all running on a stage 4 setup?
VWGrk1 is offline   Reply With Quote
Old 12-19-2005, 11:50 AM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
I was asked by Steve when I ordered my kit (purchased directly) what size nozzle and was given two options; WRX nozzle or STI nozzle. I choose the sti and run it on my stage-4 2.0L without problem (tuned accordingly of course). No idea what size the “STI nozzle” actually is…
xcntrk75 is offline   Reply With Quote
Old 12-19-2005, 07:05 PM   #3
VWGrk1
Member#: 57882
2004 WRX
Yeah, I think that I might have the STi nozzle, but that is odd that it works for you just fine.
Anybody else?
Old 12-20-2005, 05:15 PM   #4
VWGrk1
Member#: 57882
2004 WRX
Anybody else?
Old 12-20-2005, 05:54 PM   #5
kedrin
Member#: 48380
maybe you are running to much pressure through your nozzles?
dunno just a thought
kedrin is offline   Reply With Quote
Old 12-21-2005, 01:21 AM   #6
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
does your controller have a set of dipswitches on the side of it , if so then you can raise or lower the max pressure the pump pushes, as for nozzle size i'm at stage 2+ and run a #7 at about 100psi max on the pump with the stock td04 and at wot she pulls pretty hard but i could possible get away with a #5 or #6 at a lower max psi , but since i've got bigger turbo plans the #7 is ok by me.
mike
tribalwrx is offline   Reply With Quote
Old 12-21-2005, 01:24 AM   #7
testes1010
Member#: 47145
2012 Gas Saver
I know Jorge recommended a 5-7gph nozzle before he tuned my setup...
testes1010 is offline   Reply With Quote
Old 12-21-2005, 09:30 AM   #8
VWGrk1
Member#: 57882
2004 WRX
mike
The only dipswitch is me for ordering a #10 nozzle
It does have a rotating dial where you select the beggining and max spray points. We put the max spray setting to the max- to a psi that I would not be able to reach. This would, in effect, lower the amount of alky injected, but it was still too much.
Old 12-21-2005, 09:34 AM   #9
VWGrk1
Member#: 57882
2004 WRX
Thanks, I'll order a smaller nozzle. You have a bigger snail and are making great power with the smaller nozzle. Wait, that didn't come out right
Old 03-03-2006, 02:51 PM   #10
wrxraaca
Member#: 81490
2002 Subaru Wrx
Blue VF-22 Equipped
I just ordered a kit..and I told him i have vf22 w/ fmic and going to be hitting 22 psi. He said I should get a STI nozzle..#10...so thats what I went with.
wrxraaca is offline   Reply With Quote
Old 03-05-2006, 09:02 PM   #11
VWGrk1
Member#: 57882
2004 WRX
Keep us updated on how that works out for you.
Old 03-06-2006, 12:03 PM   #12
Davenow
Member#: 23676
It all depends how much air you are pushing.
There is nothing wrong with using a 10 on a WRX, as long as you are pushing a lot of air, and if you are feeling like you are flooding the motor, just pull more fuel out.
What A/F are you at?
I know a guy running like a 15 on his STI with his rotated mount setup with great success.
Old 03-07-2006, 09:06 AM   #13
VWGrk1
Member#: 57882
2004 WRX
I am running an 18G stg 4 setup. Not sure how to quantify how much air I am pushing, but on my non-alky UTEC map I see MAF voltage of 4.5 in the high rpm range. 20-21 psi peak tapering to 18.5 psi in the 6000+ range. I am having an odd issue with holding boost in the 6000+ range that I won't get into right now.
Jorge, my tuner, was shooting for at least another 2-3 psi accross the board with alky, IIRC.
Old 03-07-2006, 09:47 AM   #14
wrxraaca
Member#: 81490
2002 Subaru Wrx
Blue VF-22 Equipped
I bet its the boost controller...im having trouble holding boost over 18 psi. The stock solenoid is not strong enough, so I picked up a Perrin Boost Solenoid, now it holds boost perfectly...
Old 03-07-2006, 03:17 PM   #15
klattery
Member#: 48503
2004 STi ATP3071
For clarification, SMC kits come with 7, 10, or 15 size nozzles. 7 is for most WRX setups and 10 for most STi setups. But those with heavily modified WRXs, Steve recommends a 10. A heavily modded STi will run a 15, as would a very heavily modified WRX.
In your case, I would think a stage 4 WRX running an 18G should be at least comparable to a Turboback STi like me. And Steve recommended I get a 10. Unfortunately I am waiting on a tune so can't tell you how my 10 size nozzle is running. But if you really think its not working give Steve a call and get a size 7.
klattery is offline   Reply With Quote
Old 03-07-2006, 03:53 PM   #16
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
Steve @ SMC said he included the standard #7 nozzle in my kit and I am running an APS S/R30 turbo (263hp @ the wheels). I cant wait to get my '02 tuned with the alcy injection!!!!
BVM is offline   Reply With Quote
Old 03-07-2006, 03:56 PM   #17
wrxraaca
Member#: 81490
2002 Subaru Wrx
Blue VF-22 Equipped
You might need a #10...
Old 03-08-2006, 12:49 PM   #18
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
#7 is fine. I have tdo5 18g with a FMIC and I am running #7 nozzle. Works great and gained 50/50 hp/tq.
CoolRex is offline   Reply With Quote
Old 03-08-2006, 01:43 PM   #19
wrxraaca
Member#: 81490
2002 Subaru Wrx
Blue VF-22 Equipped
Thats a damn good gain...would any of you guys be able to post a log...I want to see what kind of timing you guys are getting w/ the 50/50 meth and water...
Old 03-08-2006, 03:17 PM   #20
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Got to add like 5-6 degrees and the car still taking to more but we hit the limits of the stock WRX tranny and engine in terms of reliability....didn't want to take my chances.
Old 03-09-2006, 10:09 AM   #21
VWGrk1
Member#: 57882
2004 WRX
I have a GM solenoid in there, so I do not think that it is the problem. The tuner and I think that it might be the UTEC because boost drops off like a switch at about 6200 rpm and comes back, like a switch, at about 7000rpm. Very, very wierd.
I want to try using an MBC to see if it is the UTEC's boost control or not that is causing this issue.
Old 03-09-2006, 10:39 AM   #22
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
My tuner and I was seeing the same issue on another guys STi with FP Red turbo. IT would boost great then out of nowhere *poosh* boost drops and then climbs right back up. It is almost like the wastegate blew open and then closed back up. Tuning with EcuTek and very very wierd. We tightened the wastegate arm several times and it still did it. Another tuner also had the same issue with another car also with FP Red. Feels like the turbo is blowing the wastegate open.
Old 03-09-2006, 10:45 AM   #23
VWGrk1
Member#: 57882
2004 WRX
Yeah, we tightened the arm, but to no avail. This is the third turbo that I have had this issue with. The first was a modded stock turbo (kind of hard to blame the EM since it is a small snail) then a VF22 and now this one.
Old 03-09-2006, 11:42 AM   #24
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Honestly I would look into the GM solenoid if it was there the entire time.
Old 03-09-2006, 11:50 AM   #25
steelhead
Member#: 93576
I am upgrading to a fp green on my Sti and don't know whether to run a #10 or #15, anybody have an answer?
steelhead is offline   Reply With Quote
Anyone running 18's? What size tires are you rolling on? Knightmare69 Tri-State Area Forum 34 02-20-2007 07:40 PM
Espelir JGT500R users, What exhaust hangers are you running? "B" Newbies & FAQs 4 06-22-2006 08:09 PM
What size injector are you STI guys running? scoobie1 Water/Methanol Injection, Nitrous & Intercooler Cooling 14 04-04-2006 10:39 PM
what size tires are you guys running for hpde racekar Motorsports 4 03-12-2006 02:04 AM
Whats the largest size tire I can run? What size tires are you running? 03SubaWRX Tire & Wheel 10 11-18-2003 06:06 PM
