Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 12-19-2005, 07:17 PM   #1
edjack
Member#: 99470
1998 Legacy Outback
Default Special tools for timing belt replacement
Anyone know of a place that rents the special tools for replacing the timing belt on a 2.5 liter twin cam?
There are 4 required:
Holder for crankshaft to remove pulley bolt
special socket for turning engine over.
2 holders for the cam pulleys to prevent movement
edjack is offline   Reply With Quote
Old 12-20-2005, 11:55 PM   #2
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I don't know of any sites that sell them but I do know there are a lot of ways around them...
To remove the crankshalf pully you can put it in 5th gear and hold the brakes then with a breaker bar take the bolt off... its what I did to install my light weight pully
To turn the engine over you can just put the bolt back in and with the breaker bar again just turn it over... it's not that hard to turn over
as far as holding the cam pully goes... theres a way to do it but I don't remmeber
scobaru is offline   Reply With Quote
Old 12-21-2005, 01:35 AM   #3
xS2k
Member#: 85112
OR to take out the crank pulley out. Put the breaker bar to the ground, take out all ignition wires, hit the starter (turn on car), and it'll loosen up in less then a sec. To reinstall, just have someone hold the brakes and tighten the crank pulley bolt. Iff you want a better explaination, a simple search will provide you with much more info. It was my first time doing it, so it's very simple and not hard at all. You might want to have a friend help you out.
xS2k is offline   Reply With Quote
Old 12-21-2005, 03:35 PM   #4
ursmother
Member#: 64447
I was just told yesterday that doing a timing belt job on a subaru is a PITA. It's not so much the changing of the belt, but it's that EVERYTHING has to be resealed after you change it. This true?
ursmother is offline   Reply With Quote
Old 12-21-2005, 08:24 PM   #5
avk
Member#: 17252
'06 WX8
59E
http://subaru.spx.com is where you can buy the tools. They are not strictly necessary but it's your call. Everything about t-belts (including the tool site) has been regurgitated here numerous times, just look it up.
avk is offline   Reply With Quote
Old 12-21-2005, 08:33 PM   #6
kheff46
Member#: 66739
2002 WRX wagon
under three hours for your first time. that includes doing main and cam seals. i did a h20 pump and thermostat 'cause i was already in there. but after you do it once or twice, an hour and a half is normal. basic tools required, nothing fancy, but certain special tools help shave a 'lil time. check idlers and tensioners while you're in there, tensioners are questionable, but can be reused(i've gone 45k after reusing mine that had 135k)! good luck! -keith
kheff46 is offline   Reply With Quote
Old 12-21-2005, 09:00 PM   #7
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
you have a swap in yours?? what tensioner did you use? usdm wrx one?
Old 12-22-2005, 01:19 AM   #8
edjack
Member#: 99470
1998 Legacy Outback
Thanks to all who responded. I'll do some research.
Happy Holidays to all!
Old 12-28-2005, 07:36 AM   #9
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
use the 98 dohc RS tensioner. usdm ej205 is the new age camset and pulley front set. good change it works, but if buying new id buy the 98 dohc rs one.
fyi- ive put a jdm 95 ej20g STi tensioner and all timing belt pullies (and water pump) on a 94 ej18. quite hilarious. (u obviusly need sohc timing belt)
swapstar is offline   Reply With Quote
Old 12-28-2005, 10:24 AM   #10
emyselfandi
Member#: 83701
so i got my 2.2 all bolted back up and ready to go but I can't get enough torque on the cam pulley bolt... I need to get this thing back on the road. I see above that you can hold the brakes and tighten it? is that correct? I plan on rollin down to sears and picking up a belt holder tool (like the oil filter tool only bigger) and trying with that. please help a brotha out. tim
emyselfandi is offline   Reply With Quote
Old 12-28-2005, 10:41 AM   #11
Hayes
Member#: 11808
On my 2.5L engine there is a bellhousing hole just under the left side of the intake manifold. Remove the rubber plug and lock the flywheel using a long strong screw driver. Torque the crank bolt to 130 ft/lbs. The socket size for my crank bolt was a standard 22mm 6 point. You must/should somehow lock the cams before removing the timing belt and before the belt is remove turn the engine over untill ALL the sprocket and crankshaft marks are aligned.
Hayes is offline   Reply With Quote
Cam locking tools for timing belt changes... where to rent/borrow? Buttsy Service & Maintenance 2 02-10-2008 09:56 PM
Anyone near Greenville, SC - Need Subaru tools for timing belt job rubberman South East Region Forum 13 03-09-2007 11:52 AM
special tools for wheel bearing replacement? mamiyarz67 Transmission (AT/MT) & Driveline 28 08-16-2006 03:01 PM
Special Tools for Timing Belt replacement Gorge Service & Maintenance 6 02-17-2006 05:41 PM
Special tools for timing belt replacement? 1wickedwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-14-2004 01:57 PM
