Old 12-19-2005, 09:06 PM   #1
2002bugeye
Member#: 99862
Default swapping from 2002 5 speed to 2005 sti 6 speed what do i need
Could someone please give me a list of parts i need to perform this swap correctly. I looked at other threads and i just want to know a parts list plain and simple thanks
2002bugeye is offline   Reply With Quote
Old 12-20-2005, 06:28 AM   #2
VpointVick
Member#: 93193
'03 325iT
Mysticblau
This was in the first post of this thread.
Originally Posted by Bayley
Transmission:
$2500
3.9 Ratio Differential:
$300
Automatic Transmission Driveshaft:
$50
STi OEM Shifter Linkage:
$40
Transmission Mount:
$70
Misc. brackets from dealership:
$30
Clutch Fork from 6 speed:
$50
VpointVick is offline   Reply With Quote
Old 12-20-2005, 07:19 AM   #3
02WRX03060
Member#: 19897
02WRX03060 is offline   Reply With Quote
Old 01-28-2006, 12:37 PM   #4
phatfil
Member#: 15956
13 XV Crosstrek
13 FR-S Asphalt
Default front axles
so , is it safe to say that the front wrx axles will fit onto the 6MT?
phatfil is offline   Reply With Quote
Old 01-29-2006, 08:08 PM   #5
nicad
Member#: 33971
2006 WRX
depends on your 6MT. 02-03 5MTs have female axles and male axle stubs on the transmission. if you have an older 04 6MT, it will be the same design, but subaru switched to male axles sometime in '04.
you need to look at your 6MT and see if there are axle stubs or not. If no axle stubs, either get 5MT axle stubs (bitch because you have to disassemble the 5MT to get them), get 6MT axle stubs from dealership, or get the male DOJ's for your axles, or 6MT front axles. those are in order from least to most expensive.
I just did the swap, took around ~6 hours complete with changing the rear end with a 3.90 suretrac R160.
my 4EAT propshaft flange would not bolt to USDM diff flange - bolt pattern is off.
my USDM propshaft would bolt to JDM R160, but of course it was too long.
so pay careful attention to your rear diff flange and propshaft flange.
have fun!
nicad is offline   Reply With Quote
Old 01-30-2006, 02:25 PM   #6
phatfil
Member#: 15956
13 XV Crosstrek
13 FR-S Asphalt
My 6MT does have axles stubs, So I am assuming that the wrx axles are the same as the STi axles on the transmission side?, I'm just trying to figure out what my plan on attack is, cause when i took out the R160 and rear axles, I found out that the STi axles are longer on the diff side and larger diameter for the wheel side. So I was under the impression that maybe I would run into the same problem with the front and this swap would cost more than i would of hoped. But if Im correct, I would be better off getting a 3.90 ring for the R160 and everything would be good.
What happens to the center diff if the DCCD isnt wired up?
Old 01-30-2006, 07:57 PM   #7
nicad
Member#: 33971
2006 WRX
it's in open, 35/65 torque split F/R
I want to do a swap from my wrx Tranny to an STI tranny. importgurl87 Transmission (AT/MT) & Driveline 3 12-17-2008 10:38 PM
2005 STi 6 speed complete swap 2006whitesti Drivetrain 40 10-13-2008 12:03 PM
ppg 5 speed v.s. sti 6 speed swap. Jonx1218 Transmission (AT/MT) & Driveline 8 05-21-2008 04:47 PM
JDM Sti 5 speed VS JDM Sti 6 speed Ace009 Transmission (AT/MT) & Driveline 89 06-09-2007 03:26 AM
2005 STi 6 Speed Shift Knob Dasani Private 'For Sale' Classifieds 1 04-22-2006 07:15 PM
