Old 12-20-2005, 01:29 PM   #1
advanracing62
Member#: 61899
Default Replacing busings with Spherical Bearing?
I am wondering if there is someplace that sells the bearings so that I can press out my rubbers and press in the bearings?
Is there someone that already does this?
advanracing62 is offline   Reply With Quote
Old 12-20-2005, 02:14 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
might be a bit noisy, but try mcmaster.com they have lots of that stuff. not sure you will like the price, but they should have it.
PARANOID56 is online now   Reply With Quote
Old 12-20-2005, 02:29 PM   #3
advanracing62
Member#: 61899
I just want to replace one busing on the front control arm when I switch over to the alum. ones... not sure if it will really make a difference, but it might help a bit.
actually, I wouldn't mind replacing the rear trailing arm busing on the hub too.... but that's it- too loud for a street car IMO
Old 12-20-2005, 02:34 PM   #4
advanracing62
Member#: 61899
just checked the site- not horrid pricing IMO
Old 12-20-2005, 03:27 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I believe the Perrin PSRS kit is what you are looking for on the front.
For the rear poltec now makes a rear hub trailing arm bushing replacement.
Full Pillowball vs Spherical Bearings End Links Shini590 Brakes, Steering & Suspension 4 11-26-2004 08:48 PM
spherical bearing lubrication question no-coast-punk Brakes, Steering & Suspension 3 09-16-2004 09:41 PM
End-Links with Spherical Bearings, All in Stock PolTec Inc Suspension/Brakes/Handling 160 06-18-2004 02:56 PM
Are the spherical bearings on my Perrin end links supposed to be this stiff? dsc Brakes, Steering & Suspension 1 02-21-2003 12:41 AM
Spherical Bearings on Endlinks - good or bad? djerickd Brakes, Steering & Suspension 16 11-19-2002 07:03 PM
