Old 12-20-2005, 04:57 PM   #1
Cstmboxermotorsports
Member#: 103340
1992 RHD WRX
Default EJ22 heads on an EJ18
Ok so im just screwing around with a bunch of engines i have laying around and I decided to make an incredibly fast EJ18. Now I've heard of people putting EJ18 head on an EJ22 to raise compression but what would happen if i put a set of heads from a 93 Turbo legacy on the EJ18 Block?
BTW i am turboing this engine with the turbo peices off of the Turbo legacy block considering their all just sitting there after i stripped down the engine for the short block.
Cstmboxermotorsports is online now   Reply With Quote
Old 12-20-2005, 06:25 PM   #2
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
I've heard of putting SVX pistons in the ej22 to raise compression, or something to that effect.
It will probably breathe better, I guess.
WRXRallyBlue is offline   Reply With Quote
Old 12-20-2005, 09:26 PM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Lower the compression...
Old 12-21-2005, 04:19 PM   #4
Member#: 103340
1992 RHD WRX
so no good for turboing
Old 12-21-2005, 04:30 PM   #5
Porter
Member#: 486
2004 Forester XT
bug spattered
Depends on what the final compression ratio is. Do the math.
Porter is offline   Reply With Quote
Old 12-21-2005, 07:36 PM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Lower compression = better for turboing.
However, with larger heads on there, you could end up with valves that will hit the cylinder wall or even the pistions because of the valve grooves on the pistions. At least that is what I found when I test fit EJ20 heads on an EJ18 block.
Old 12-22-2005, 01:49 PM   #7
Member#: 103340
1992 RHD WRX
EJ20 heads are also DOHC, unlike the EJ18 and the EJ22 which are SOHC.. would this make a difference?
Old 12-22-2005, 01:51 PM   #8
subyswamper
Member#: 91049
2008 wrx wgn
charcoal grey
I have heard that the turbo heads from the legacy don't flow as well as others.
subyswamper is offline   Reply With Quote
Old 12-23-2005, 06:45 PM   #9
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Its about valve size/piston design, and whether the valves will physically hit the cylinder walls. Its got nothing to do with DOHC or SOHC.
Old 12-23-2005, 06:46 PM   #10
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
They physically nearly identicle to the phase I EJ22 and EJ18 heads.
Ej20G heads on an EJ18, will things get banged up! turboL Built Motor Discussion 25 06-21-2011 10:24 AM
ej22 heads on ej18 motor question... scottie_ybb Subaru Conversions 6 08-29-2008 12:30 AM
Would the EJ22 bolt into an EJ18 as easy as the EJ25 bolts in? Max Umbarger Subaru Conversions 16 02-27-2004 11:51 AM
The Legendary EJ20 heads on an EJ18 block experiment Kostamojen Subaru Conversions 15 01-14-2004 12:10 PM
Serious hypothetical question: What is needed for EJ20 heads on an EJ18 block? Kostamojen Normally Aspirated with bolt-on Forced Induction Powertrain 11 01-12-2004 01:42 AM
