Old 12-20-2005, 05:10 PM   #1
stevo2234
Member#: 69853
2005 WRX
gold
Default CEL light
My CEL has been on ever since I got my utec I had someone pull the codes for me today and they came up with this, btw current mods are, 9lb pro-lite flyhwheel, exedy stage I clutch, TXS stage III base map with FMIC untuned btw
1. P0137- ( o2 sensor circuit low voltage) ( bank/sensor 2)
2. P0546- Exhaust Gas Temprature Sensor Circuit High ( Bank/sensor 1)
3. P0519- Idle Air Control System Performance
I thin the third one is from the flywheel, on any note how do I get rid of these?
stevo2234 is offline   Reply With Quote
Old 12-23-2005, 12:08 PM   #2
stevo2234
Member#: 69853
2005 WRX
gold
bump, please help cant pass inspection with CELs
Old 12-23-2005, 12:35 PM   #3
chapstien
Member#: 68284
1988 Corolla SR5
0-points
You can turn off the cel in the software.
If your EGT burned, there is a mod to replace it with a resistor.
Why are you running a StageIII map? Did you just not list all your mods?
chapstien is online now   Reply With Quote
Old 12-23-2005, 08:02 PM   #4
stevo2234
Member#: 69853
2005 WRX
gold
no, im running full stage III and then some so no not all my mods were listed, just those I thought might be relevent
Old 12-23-2005, 08:04 PM   #5
imprezive one
Member#: 16906
2k3 wrx wagon
Wait, the utec allows you to turn off the CEL? I thought only the AP had that feature. Is this something new that was added?
imprezive one is offline   Reply With Quote
Old 12-23-2005, 09:12 PM   #6
JNUTZ
Member#: 90132
2003 WRX
Rally Blue
^^^same here, Is there a way to turn of the CEL with the utec?
JNUTZ is offline   Reply With Quote
Old 12-23-2005, 09:23 PM   #7
imprezive one
Member#: 16906
2k3 wrx wagon
I'd say the O2 sensor code means your sensor is bad. Usually if you're catless and the O2 sensor isn't seeing the readings it wants you'll get a cat inefficiency code, not a low voltage (at least in my experience). Look into replacing it. If you end up getting a cat inefficiency code after that you can just swap your stock exhaust on when you take the emissions test and then put the aftermarket one on after you pass.
Your EGT sensor is probably burned like someone else mentioned, so you'll prolly have to replace that too & I have no clue about the idle air code. Good luck, I'm in the process of temporarily de-modding to pass stupid e-check. What a PITA.
EDIT: did a little bit of searching... the new firmware 5.0 allows you to turn off the starting CEL sequence (that tells you what map number is loaded right now), but that doesn't have anything to do with actual CELs. Darn it, back to square one.
CEL Light and Cruise light on miiike Service & Maintenance 2 05-09-2010 09:59 PM
CEL light code P0244 then light clears??? ChrisCJ99 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-01-2006 01:09 PM
hey if any houston guys get a CEL light pop up jmott Texas Impreza Club Forum -- TXIC 7 09-06-2001 01:50 PM
