Old 12-20-2005, 08:54 PM   #1
mx_9
Member#: 36138
2015 2015 Focus ST
Magnetic Metallic
Default AutoX tire width input needed: 04 STi with 7.5" rims
I've searched through various sites looking for info regarding tire sizing on the stock 7.5" rim but what I mostly found was info regarding what tire sizes look good versus what can be used in competition. I'm considering Advan A032R's in soft compound for this coming autoX season and would like to go with their 245/45/17s. However, the Tirerack web site shows the minimum rim width to be 8.0". Yet, Falken shows a minimum of 7.5" for their rt-615s. So, it seems like 245's are 'doable' but not recommended by Yoko for the 245/45s. I understand the issue of bulge and potential loss of sidewall strength if using 245's on a 7.5" rim, but is the added tread width worth the tradeoffs? I am far from smooth, so does the potential to break a bead increase with far-from-smooth transitions? Any input would be appreciated.
I will also be buying a set of RT-615's as daily drivers so it will be interesting to compare the two tires (I'll get them in the same size).
I will be running in SM due to: a) ECUTEK and TBE, and b) no one is running locally in BSP.
04 STi
Front camber: -1.4
Rear Camber: -1.8
JDM pinks
Thanks, Chris
mx_9 is offline   Reply With Quote
Old 12-21-2005, 12:25 AM   #2
qcslvr30
Member#: 42041
2006 WRX STI
aspen white
I ran 245-45-17 v710's on my stock BBS's. They fit the wheel fine. If your going to run the yok's I think the 245-40-17 would be better. My 245-45's fit but do rub the front inner fenders.
James
qcslvr30 is offline   Reply With Quote
Old 12-21-2005, 10:18 AM   #3
ratt_finkel
Member#: 46218
06 EVO 9
Don't waste your time on the Yok's. If you're worried about longevity. Go with some Victoracers, they should last you more than a season are much sticker and cheaper than the Yoks.
ratt_finkel is offline   Reply With Quote
Old 12-21-2005, 11:59 AM   #4
Fred
Member#: 3560
06 STi, 02 WRXes
94 Open Light 2.5RS
And get some camber bolts from Dale - I'll help you install them. You NEED more camber in front.
Fred is offline   Reply With Quote
Old 12-21-2005, 12:05 PM   #5
ghostshadow
Member#: 77519
05 sti
white
not sure about lasting more than a season? my victoracers dropped off about halfway through the season, corded about 3/4 of the way through.. i guess it depends on how many events you run..
but i agree, i'd take the victoracers any day of the yoks.
i also saw a huge improvement in tire wear once i installed the strano bar.. an added benefit besides the improved handling.
ghostshadow is offline   Reply With Quote
Old 12-21-2005, 12:27 PM   #6
makofoto
Member#: 25243
2006 Legacy Outback
I know of a STU STI driver that won a National Solo2 event using 245/45/17 Azenis's on stock 7.5" wheels ... so that've quite do-able ... but you REALLY should get some relatively inexpensive 8.5" Rota Slipstreams. To bad I just sold my two sets.
makofoto is offline   Reply With Quote
Old 12-21-2005, 12:32 PM   #7
mx_9
Member#: 36138
2015 2015 Focus ST
Magnetic Metallic
Wouldn't more camber increase the likelihood of rubbing on the inside of the tire? I'm just hoping to get 245's on there without any type of rub. Front or back. What size tires are you running on your 04 this year?
Old 12-21-2005, 01:22 PM   #8
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Yokos run wide, so get the 235. The 245 Yoko is too wide for an 8" wheel
Obligatory Hankook > *.* comment
-Tom
trhoppe is offline   Reply With Quote
Old 12-21-2005, 01:28 PM   #9
cbarth3
Member#: 67249
2004 WRX
well i don't see why the 245 wouldn't be do able as i run a 245/45/16 on the stock wrx wheels. granted i do put a 1/4 inch spacer to accomodate them
cbarth3 is offline   Reply With Quote
Old 12-21-2005, 04:38 PM   #10
Fred
Member#: 3560
06 STi, 02 WRXes
94 Open Light 2.5RS
I'll be running the 225/45/17 RE070's until they're gone (shouldn't take much more than the 2nd annual 240SX vs. WRX driftoff at the Test & Tune ), then the 225/45/17 RT-615's that are currently in use for daily driving.
I'm not fast enough to get 100% from 225's, so 245's would be a waste of money.
Old 12-21-2005, 05:24 PM   #11
solo2wrx
Member#: 87982
05 Intrepid
125cc of 2 stroke fury
There are several guys I know that have run 245s with 3+ degrees negative camber in front without any rubbing issues so the 2.5 degrees or so you will get with camber bolts should be fine.
solo2wrx is offline   Reply With Quote
Old 12-21-2005, 06:19 PM   #12
Draken
Member#: 16
1968 Saab
Sonett II V4
i'm running 255/40-17 Pirelli Corsas on 17x8 Rotas on my '04 STi. Zero rubbage. I have Tein Flex 10/8 setup, 13.75" ride height. Plenty of room in the back. I only rub a little on the left front fender liner when I come off the last turn at Thunderhill and nip the curb. And i think that fender liner is a little out of place from when i rubbed it during my 275/40-17 Hoosier days.
static photo:
Chris H.
Draken is offline   Reply With Quote
Old 12-21-2005, 09:44 PM   #13
mx_9
Member#: 36138
2015 2015 Focus ST
Magnetic Metallic
Kevin..thanks for taking the wind out of my sails! I'm not fast enough to get 100% out of 155/70/17's but plan on getting more rubber anyway. I think your speeds in the STI will have you wanting more lateral grip with the way you'll be entering elements at mach-2.
Old 12-22-2005, 08:05 AM   #14
Fred
Member#: 3560
06 STi, 02 WRXes
94 Open Light 2.5RS
Hey, if I wanted grip I'd get R compounds, not switch to barely wider street tires. I'm looking forward to autoxing the STi this year not because of how fast I can go in it, but because of how much fun I can have going fast sideways.
Old 12-22-2005, 11:01 AM   #15
jamesohoh7
Member#: 39070
GTF off my lawn!
I hear ya on the sideways thing... then again, at our driver meetings each race, they make it a point to announce "This is not a drifting event..." boooo!
jamesohoh7 is offline   Reply With Quote
Old 12-22-2005, 01:45 PM   #16
Fred
Member#: 3560
06 STi, 02 WRXes
94 Open Light 2.5RS
We have a guy in our club named Randy Melton - has a Mustang that he runs in ESP. Used to have a V8 Pinto that sometimes ran FTD. Great - and I mean GREAT! - driver. Year before last, he would bring the Mustang out on bald street tires and drift the entire course from start to finish, and even last year on 315 V710's he would sometimes spin through the finish if it was safe to do so and then do a couple of donuts afterward. Highly entertaining, but the officers had to ask him to tone it down because he was "setting a bad example for the novices."
Old 12-22-2005, 07:11 PM   #17
REX8
Member#: 24038
Sure the Yok's dont have the grip of the Vic's, but as far as longevity, the Yok's will SIGNIFICANTLY outlast the Vic's. So if he's looking for longevity, the yok's are the way to go.
Old 12-22-2005, 07:42 PM   #18
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Most people with -3 degrees of camber are getting it with camber plates, those dont affect strut to tire clearance. Doing it through the camber bolt puts the tire closer to the strut which could lead to rubbing issues.
afpdl is offline   Reply With Quote
Old 12-22-2005, 07:42 PM   #19
mx_9
Member#: 36138
2015 2015 Focus ST
Magnetic Metallic
I'm actually just looking for a 'better' tire for AutoX that can be used on 7.5" rims without any kind of modification to make it work. I kind of settled in on the A032Rs since they *can* be driven to events if desired. Plus, GRM August edition, had some good things to say about them with respect to first-timers on R-comps. That's me It's now simply a matter of do I try to stay close to stock size or do I/can I upsize without rubbing.
Old 12-22-2005, 07:51 PM   #20
REX8
Member#: 24038
In your case, I like the Yok's. Since you're autoxing for fun, long lasting tires, that are great in the rain, that can be run on the street seem like a good fit for you. No one is going to recommend the "slower tire", well maybe no one except me. Don't rule out the "H" compound either. You're car is heavy, so if you plan on doing any track days (which you REALLY need to try), your tires will last forever.
Old 12-22-2005, 08:10 PM   #21
mx_9
Member#: 36138
2015 2015 Focus ST
Magnetic Metallic
I appreciate the input...Thanks. What I meant by 'better' was that I am considering something other than the RE070s that I've been using and it's my understanding that I'll have to go wider to get something that is stickier than them. Pure race tires like Hoosiers are not an option at this point.
Old 12-23-2005, 11:09 AM   #22
corey_dyck
Member#: 98427
2006 STI
A032R's will heat-cycle to death before they run out of tread, but they'll last a fair bit longer than Victoracers.
Toyo RA-1's are about 1/2 way between the two. A little faster than the Yok but wears a little faster. The Toyos keep getting faster until they cord.
corey_dyck is offline   Reply With Quote
Old 12-23-2005, 11:32 AM   #23
ratt_finkel
Member#: 46218
06 EVO 9
You can drive the Victoracers on the street as well. I still say the Yoks are a waste of money. Sure the tread lasts a long time, but any usable performance will be long gone before that.
Old 12-23-2005, 12:21 PM   #24
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
Basically, he is looking for a tire that is better than stock (more grip), that he can drive to the event on, drive back home, and change to street rubber. Anything that can take that (100+ mile trips x 8 ) and not heat cycle to death in one season == good
Drakken:: When you had clearance issues, it was on the inside of the tire on a +48 offset 8" rim? You ever run the 255s on the 7.5" (or I missed it)? What alignement settings were you running?
Just trying to help out, Chris
- dow
dowroa is offline   Reply With Quote
Old 12-23-2005, 12:25 PM   #25
makofoto
Member#: 25243
2006 Legacy Outback
Used Toyo RA-1's for sale here ... 3 to 4 heat cycles. In WRX perfect 235/40/17. I don't think they have other sizes.
http://tinyurl.com/8ro2w
Goto Clearance/Used items at the bottom of that page ... find RA-1's. This company races BMW's in the World Speed Challenge series ... where the RA-1 is the Spec tire.
Two Quality levels, $50 and $100 a piece ... perhaps a good way to try them out.
Largest tire width on stock 06 STI rims? ILSMKU2 Tire & Wheel 39 11-08-2007 01:53 AM
ADR Phantom 18" x 7.5" Rims 5 Lug with Tires ThePunisherGT NESIC Private Classifieds 36 02-26-2007 11:36 PM
Rubbing with 7.5" and 225 wide tires MRF582 Brakes, Steering & Suspension 4 07-05-2005 03:05 PM
Whats the widest tire for a 7.5" rim imprezkid Tire & Wheel 8 01-05-2005 08:38 AM
235 width w/ 7.5" rim? BIGSKYWRX Brakes, Steering & Suspension 24 01-02-2003 12:46 AM
