Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 12-20-2005, 11:52 PM   #1
AugustusMaximus
Member#: 63060
0005 RS, 92X
silver, red
Default WRX intake manifold vs. STI intake manifold
I think the STI has a slightly larger port diameter but I could be wrong. Anybody know the exact figures/specs?
AugustusMaximus is offline   Reply With Quote
Old 01-27-2006, 11:58 AM   #2
Jitenshakun
Member#: 61586
2005 STi
WI and all the goodies
bump.
Is fitment the same too?
-J
Jitenshakun is offline   Reply With Quote
Old 01-27-2006, 12:09 PM   #3
Davenow
Member#: 23676
fitment is the same
The only difference is the red paint. The ports/runners are the same, as its the same manifold. (the paint supposedly has some heat retention/sheilding properties, but I am not sure I believe that)
Old 01-27-2006, 03:09 PM   #4
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
As Chris Farely has said, "That is correct"
parker/slc/gc8fan is offline   Reply With Quote
Old 01-27-2006, 04:05 PM   #5
Jitenshakun
Member#: 61586
2005 STi
thanks guys.
-J
Old 01-27-2006, 04:27 PM   #6
Davenow
Member#: 23676
So do we have any definative data on the red coating? Is it a thermal coating as many have said, or is it just paint like it seems to be (from the chips of it I have held in my hand, it sure as hell seems to not be thermal material)
Old 01-27-2006, 04:28 PM   #7
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Thats a good question.
I havent seen any tests.
Want to source the paint from FHI?
Old 01-27-2006, 05:35 PM   #8
wgknestrick
Member#: 32576
04 STI
Red "paint" is mearly red crinkle powder coat.
wgknestrick is offline   Reply With Quote
Old 01-27-2006, 07:03 PM   #9
Davenow
Member#: 23676
This is a completely useless reply since you provided no data to back it up.
I agree that it most likely is. But we are looking for HARD DATA here.
Old 01-27-2006, 07:12 PM   #10
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
If it were actual powdercoat I think it would probably stick much better than it does.
snwman is offline   Reply With Quote
Old 01-27-2006, 07:46 PM   #11
Jitenshakun
Member#: 61586
2005 STi
Umm, where is your "HARD DATA" for the WRX and STi manifolds being the same?
Glass houses and stones....
-J
Old 01-27-2006, 07:51 PM   #12
gonzfather
Member#: 23830
2013 Subyota GT-86
Casper
PWN3D
-J
Touché
gonzfather is offline   Reply With Quote
Old 01-28-2006, 07:03 PM   #13
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
STI manifold has a slightly larger diameter intake (where the T-body lines up). You'll get a lot better results with the match ported T-body as well as porting hte manifold though.
Cheer,
Gary
Gruppe-S is offline   Reply With Quote
Old 01-28-2006, 08:21 PM   #14
Davenow
Member#: 23676
-J
I am asking about the coatings.
And the 3 STI manifolds I have held in my hands, and measured the inside of the runners, were identical to the couple WRX manifolds I have measured.
Old 01-28-2006, 08:27 PM   #15
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
I don't htink the paint does anything.
Gary
Gruppe-S
Old 01-28-2006, 08:28 PM   #16
Jitenshakun
Member#: 61586
2005 STi
I think I found some HARD DATA on the red paint
Thank you for your comments.
-J
Old 01-29-2006, 05:50 AM   #17
WaXed
Member#: 88273
2003 STi 2.0L
I wish we could get some "hard data"
what are the measurements STI port runner diameters eg. and standard port runner diameters? then...
WaXed is offline   Reply With Quote
Old 01-29-2006, 03:56 PM   #18
flwrx
Member#: 35944
'03 v7/6mt/30r wrx
MBP
So the runners are identical, only a slight difference in size behind the TB? Whats the reason for the small enlargement on the STI manifold ?
flwrx is offline   Reply With Quote
Old 01-29-2006, 11:00 PM   #19
wrx614
Member#: 71848
2003 WRX
Just for the record, usdm sti intake manifolds and usdm wrx intake manifolds are not interchangable. The throttle bodies are different and have different mounts.
wrx614 is offline   Reply With Quote
WRX VS STI exhaust manifold Cbgrandtheftauto Newbies & FAQs 8 08-09-2009 11:15 PM
Slowmotion EL manifold vs. Perrin EL Manifold SW00P_G Proven Power Bragging 31 02-19-2009 03:00 PM
'06 WRX exhaust manifolds vs. STi manifolds 1-3-2-4 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 05-08-2006 10:34 PM
WRX vs. STi Intake Manifold Carlito2002WGN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-24-2005 12:54 PM
