Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 12-21-2005, 11:15 AM   #1
fizzak
Member#: 84968
2005 WRX
Default The unhooked green connector under the dash?
What does that do and why does my car run like shyte with it connected?
fizzak is offline   Reply With Quote
Old 12-21-2005, 11:21 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's used for dealer PDI and test/diagnostic functions, and should not be connected at any other times (unless you get an AP which uses this mode to load maps).
When connected, the CEL will flash continously and various relays and solenoids in the car will cycle, as well as the engine fans. If you drive the car in this mode there will also be codes set.
Unplug them, and leave them that way.
Old 12-21-2005, 11:22 AM   #3
fizzak
Member#: 84968
2005 WRX
Thats what I thought, thanks.
Old 12-21-2005, 11:52 AM   #4
pdxsilverwrx
Member#: 54935
Before I had Delta Dash I had my codes scanned at AutoZone. The goob who did it connected the green plug for me, must of thought he knocked it loose or something. I had to call my tuner to figure out what was wrong with my car.
pdxsilverwrx is offline   Reply With Quote
Old 12-21-2005, 05:09 PM   #5
DeKaP
Member#: 90627
2005 Impreza WRX
Obsidian Black Pearl
if you connect it, it makes your car do all kinds of weird **** when you put it in the on position, a must for ap, otherwise i dont see a need for you to be in test mode
DeKaP is offline   Reply With Quote
Old 12-22-2005, 10:35 AM   #6
TarmacRally
Member#: 85805
... Shiny & Chrome
Witness Me!
for testing and reprogramming, Youll only mess with it if you get an AP
TarmacRally is online now   Reply With Quote
Old 12-22-2005, 11:43 PM   #7
Jasvboost
Member#: 37160
RIP 04 Stg2 JBP WRX
07 SWP WRX 335/350 HTA68!
Originally Posted by TarmacRally
for testing and reprogramming, Youll only mess with it WHEN you get an AP
Fix3d!
Jasvboost is offline   Reply With Quote
Noticed a green connector under the dash disconnected? ret63 Car Audio, Video & Security 8 05-06-2010 09:12 PM
Green connectors under driverside dash plus a white one Division By Zero Engine Management & Tuning 10 03-03-2006 12:15 PM
Green Connector under steering dash in 04 STi. LESLIEx317537 Electrical & Lighting 2 07-27-2005 07:05 PM
That green connector under dash DDMan Car Audio, Video & Security 0 01-20-2002 05:38 PM
Weird green connector under dash? Eric SS Technical Forum Archive 4 08-27-2000 06:51 PM
