Old 09-10-2001, 11:57 AM   #1
MikeWRX
Member Sales Rating: (1)
Member#: 7148
2015 WRX
Smile UR
I doon know
MikeWRX is offline   Reply With Quote
Old 09-10-2001, 01:45 PM   #2
bemani
Member Sales Rating: (7)
Member#: 5673
02 bug eye, 05 LGT
Is it just the crack pulley , no other pulley replacement?
bemani is offline   Reply With Quote
Old 09-11-2001, 01:29 PM   #3
bemani
Member#: 5673
02 bug eye, 05 LGT
How heavy is it? I wonder how much better it'd be if other pulleys like the alternator and such are lightened and enlarged also.
Old 10-04-2001, 02:54 PM   #4
bmw_in_a_subaru
Member#: 9395
2002 Impreza WRX
Post Timed results?
Hi Mike,
Have you done any timed results yet regarding your crank pulley modification? If so, what were the results? Before vs. After?
Or...are the results only measured "seat-o-pants"?
bmw_in_a_subaru is offline   Reply With Quote
Old 11-03-2001, 06:28 PM   #5
angus
Member Sales Rating: (3)
Member#: 10664
2002 WRX Wagon
Thumbs up
Just did mine today. Notes:
1. Easy...even I could do it.
2. Stock pulley is massive.
3. Take 3 extra minutes to remove driver-side fan, and there is PLENTY of room to work.
4. I used a torque wrench w/bar to remove bolt to check factory install and found it to be about 120 ft-lbs; if you have a new car this bolt is easy, definitely NOT a tool-breaker.
5. Improvement IS without a doubt noticeable.
6. Not a bit of dimming at idle with EVERYTHING stock turned on.
angus is offline   Reply With Quote
Old 11-03-2001, 06:31 PM   #6
angus
Member#: 10664
2002 WRX Wagon
Notice more than enough spce to work with driver-side fan removed...
Old 11-03-2001, 06:33 PM   #7
angus
Member#: 10664
2002 WRX Wagon
Add 1 hp for looking good too...
Old 11-03-2001, 07:35 PM   #8
dhs
Member#: 11575
Am I nuts or is the stock pulley a combo pulley and crank harmonic damper?
dhs is offline   Reply With Quote
Old 11-04-2001, 07:54 AM   #9
angus
Member#: 10664
2002 WRX Wagon
sshhhh! Don't even say those words...you'll start another 10-page debate on the subject.
Old 11-04-2001, 09:52 AM   #10
dhs
Member#: 11575
Oh, I did a search and can see this has been a heated debate, and I'll take it that the stocker is a balancer as well. Forget I mentioned it
WC Lathe Works shift knob extender & UR underdrive pulley for WRX designfate SCIC Private Classifieds 10 04-06-2008 03:50 PM
UR underdrive pulley on AFI phase-I motor issues STi-Nismo Dood Normally Aspirated with bolt-on Forced Induction Powertrain 7 05-23-2004 09:31 PM
Belt Size for UR underdrive pulley RugDoc2003 Transmission (AT/MT) & Driveline 1 11-03-2002 03:24 PM
RESULTS! UR Pulley on WRX McKenzie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 06-12-2001 02:11 PM
UR underdrive pulley worth installing? IMPREZA GUY Normally Aspirated Powertrain 27 06-10-2001 12:13 AM
