Old 12-21-2005, 11:42 AM   #1
vile
Member#: 32371
'02 t-rex wagon
platinum
Default choosing an air compressor
ok, i'm finally in the market for an air compressor. this will be a general purpose use compressor, meaning it will see duty from auto repair to home improvement. i'm looking to stay under $300 if possible
what do you guys/gals recommend and what should i be looking for?
so far, i've heard that i should get one that is at least 25 gallon and has a scfm of at 4.5/90 psi
by the way, i need a horizontal compressor
vile is offline   Reply With Quote
Old 12-22-2005, 02:13 PM   #2
edjack
Member#: 99470
1998 Legacy Outback
I would not buy an oilless unit. They do not hold up as well as the traditional iron block piston type. They also have a funky sound when running. But, they are cheaper.
I have an old Craftsman 240V 2 HP unit, 20 gal tank, 125 psi max, 7.4 SCFM at 90 psi. It keeps up easily with my impact wrench when rotating tires.
Most power tools today are coming from China. Some good, some bad.
edjack is offline   Reply With Quote
Old 12-22-2005, 03:02 PM   #3
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
http://forums.nasioc.com/forums/showthread.php?t=906153
I listed the compressor I use. Speaking of oiless/oiled, good luck locating a 115v 15amp oiled compressor for less than $300. I also prefer a compressor that runs on oil for less sound and longer life but they are quite a bit more expensive.
conker69 is offline   Reply With Quote
Old 12-22-2005, 09:37 PM   #4
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
My advice can be found inside here: http://forums.nasioc.com/forums/show....php?p=8434463
Anybody equipping a garage need an air compressor? Neek Off-Topic 6 05-13-2005 10:51 AM
In the market for an air compressor. Good one cheap? Where? Drew888 Southern California Impreza Club Forum -- SCIC 2 02-03-2005 10:14 PM
How loud is an air compressor/impact wrench? TimStevens Service & Maintenance 37 09-10-2004 07:07 PM
Does anybody dry off their car with an air compressor? wcbjr Texas Impreza Club Forum -- TXIC 15 09-02-2004 06:24 AM
Reccomend me an air compressor, please TimStevens Off-Topic 26 08-11-2004 03:55 PM
Message Board Statistics All times are GMT -4. The time now is 11:57 AM.
