![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 58926
Vehicle:2013 WRX Wagon-Silvr 1992 Miata - red |
I know the stockers aren't the best, but it seems that my 32/29 is not what most people here use. What is the benefit/cost of increasing pressure, and to what psi?
#2 |
Member#: 12
Vehicle:2005 M3 Mystic Blue |
That will depend a lot on how you drive, but I was running 36 up front and 34 in the rear and that seemed to work pretty well for me. I do tend to take corners at a good clip.
#3 |
Member#: 58926
I Thought I could get more thoughts on the matter?
#4 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
#5 |
Member#: 83494
Vehicle:2004 WRX Wagon Red |
I run 35F 32R, but still have more wear on the outside of the tire. I like this combo the best. You just need to play around with it and see what works best. There isn't one set number.
#6 |
Member#: 73197
International
at what temp should i take the tirepressure at? when the tire is cold...or after its been running for a while?
#7 |
Member#: 80319
TXIC
Vehicle:04 WRX WRB |
from what ive heard cold tire pressure is more accurate, take the pressure in the morning before leaving for accurate numbers
#8 |
Member#: 83494
I think in the manual it says when they are hot (normal driving), they are 3.5 psi higher or something to that effect.
#9 | |
Member#: 47769
I run the RE92's at 44F 42R for all season driving. I hate how soft the sidewalls are. |
#10 | |
Member#: 58926
Thanks everyone. |
#11 |
Member#: 60099
Vehicle:2003 Impreza RS The perty blue one |
34F 32R on Falken Ziex. Not too hard because I got stiffer Eibach Prokits and AGX's. I drive around in the inner city a lot.
#12 | |
Member#: 47769
#13 |
Member#: 44168
SCIC
Vehicle:2003 Yellow WRX with too many lights... |
I like to use whatever gives me the most even tire wear.
![]() I used to run 35f/32r on my RE92s and they wore pretty evenly. |
#14 | |
Member#: 58926
#15 | |
Member#: 58926
#16 |
Member#: 44168
SCIC
Then you'll want to go pretty high to prevent the tire from rolling over onto the sidewall when cornering. 38psi is a good starting point since that's what they recommend when you take your car to an autoX.
#17 |
Member#: 63961
Vehicle:2005 WRX Blue |
I don't have stock tires but I'm on stock size Falken 512's, 40 psi front, 26 psi rear for street driving.
#18 |
Member#: 47769
I assume you mean 36 and not 26.
#19 |
Street's closed, pizza boy
Member#: 17301
Vehicle:is the "dark side" 06 Evo #7 STU, 05 Saabaru |
I autox'd them at 42/48
Sad attempt to make the car more neutral. I dunno if you'd want to daily drive like that ![]() |
#20 |
Member#: 43853
NESIC
Vehicle:2004 WRX Sedan Stg 2 Platinum Silver |
i'm running 35F / 33R on my dunlop M3s. i would run the same if i still had my RE92s.
#21 |
Member#: 58926
Would higher than mfg recommended pressure give better grip, or just less sideways roll?
#22 |
Member#: 44168
SCIC
To a certain point it decreases roll and enhances steering response and feel without decreasing grip. You have to get pretty high to decrease the contact patch.
| Thread Tools | |
| Display Modes | |
| Best everyday pressure on non-stock tires? | skiteton | Tire & Wheel | 2 | 05-06-2008 02:32 PM |
| tire pressure on stock tires for sti? for track event | slowstangguy | Motorsports | 8 | 01-12-2005 06:24 PM |
| air pressure on stock tires | Call_me_Tom | Tire & Wheel | 13 | 05-16-2004 10:04 AM |
| Proper Tire pressure for stock tires | JDMTEG98 | STi Forum Archive | 21 | 07-23-2003 05:14 PM |
| Tire pressures for stock tires on WRX | SnortWagon | Brakes, Steering & Suspension | 5 | 02-07-2002 12:15 PM |
