Old 12-22-2005, 12:38 AM   #1
athakur999
Member#: 88307
2005 Saab 9-2x Aero
Arctic Silver
Default Crucial copper gasket and gasket spray questions
I have a set of Crucial's copper gaskets. I see that using copper gasket spray is recommended. Couple of questions:
1. Is there a limit to how far beforehand I can spray the gaskets with the spray? Can I do it a few days before I actually install them?
2. How many coats of gasket spray should I put on? Just one coat per side or should I do more?
Thanks,
Anand
athakur999 is offline   Reply With Quote
Old 12-22-2005, 02:13 AM   #2
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
I don't have an "offical" answer but I've used the spray on 2-cycle head gaskets for many many years. (also two subies)
1. It stays tacky so you can spray it well in advance. Also you can always spray a small coat on a little before installing the gaskets.
2. 2 to 3 coat is enough.
WRX03 is offline   Reply With Quote
Old 12-22-2005, 03:51 AM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I like to spray it AT LEAST 10 minutes in advance but I would not be bothered by spraying it a day in advance with perhaps another spray shortly before installation. The only thing I'd caution against is letting a sprayed gasket sit in a dusty environment too long and collecting a lot of dust.
nhluhr is offline   Reply With Quote
Old 12-22-2005, 11:56 AM   #4
supersport
Member#: 70337
2005 STi
What's that on your hood?
Read the instructions on the can. DIfferent products will have different recomendations.
supersport is offline   Reply With Quote
Old 12-23-2005, 01:04 AM   #5
athakur999
Member#: 88307
2005 Saab 9-2x Aero
Arctic Silver
Thanks for the advice everyone. I did two coats on each side today. I'll probably do another quick coat a little before actually installing them.
K&W Head Gasket and Block Repair question Benfolio Normally Aspirated Powertrain 4 10-13-2009 08:37 PM
crucial copper gaskets..CHEAP..NEW!! imxblue Engine/Power/Exhaust 7 11-12-2008 11:54 PM
crucial cu-seal copper top uppipe gasket anthonyrb98 Engine/Power/Exhaust 25 09-08-2007 06:55 PM
Crucial copper header gaskets Good2Go Engine/Power/Exhaust 1 11-12-2006 09:07 PM
Needed: Turbo to UP gasket, Turbo to DP gasket, and copper washers for oil feed line. Jard Mid Atlantic Impreza Club -- MAIC 9 08-26-2005 08:51 PM
