Old 12-22-2005, 02:41 AM   #1
WRblueX_Guy
Member#: 53247
Default Help figuring out what size fuse I need when adding another amp
Hi,
I currently have a 85x4 ch amp, bridged to put out 85, 85, 170W RMS. The front is powering a set of components and the rear is bridged to power a subwoofer. I have a KnuKonceptz 4 gauge 4 ch amp install kit with an AGU 80A fuse.
I will soon be installing another amplifier. It will be a 130x2 ch amp, bridged to power a subwoofer at 260W RMS. The 4 ch amp will continue to power the components with the front two channels, leaving the rear channels unused.
Edit: Forgot to mention... I will be using an Stinger 4 gauge Tee Distribution block for the power wire.
I'm not sure if this has anything to do with choosing your fuse, but the 4 ch amp has 4 20A fuses, and the 2 ch has 2 25A fuses. A couple people told me that because those 6 fuses add up to 130, I will need about a 130A fuse.
I have also read things like this that go mostly based off of RMS power.
http://www.mmxpress.com/technical/fusing.htm
Although, in the last paragraph it says take the total RMS wattage, divide it by the battery's voltage, and that should be your fuse size. Then when it gives the exact formula at the bottom, it says to multiply the RMS wattage by 2, divide by battery's voltage, add 10%, and that should give you the fuse size.
Would anyone be able to tell me how to figure out the approx. fuse size I would need, or if the 80A fuse will be enough?
If I did have to get a bigger fuse, I could get this holder with a 120 or 150A fuse for $19
http://knukonceptz.com/productDetail.cfm?prodID=FH-20
Thanks
WRblueX_Guy is offline   Reply With Quote
Old 12-22-2005, 02:49 AM   #2
xplcitcustmz
Member#: 82935
1972 Ford pinto
Astro Turf
Id recomend a 150 ANL fuse
xplcitcustmz is offline   Reply With Quote
Old 12-22-2005, 02:00 PM   #3
WRblueX_Guy
Member#: 53247
Thanks.
Anymore opinions?
Old 12-22-2005, 05:44 PM   #4
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
truthfully you could probably run the 80 amp and be fine. it could possibly blow at high volumes.
probably be best to go with a 120 ANL or above.
thedaddyb is offline   Reply With Quote
Old 12-22-2005, 06:37 PM   #5
blkwrx02
Member#: 38567
2002 WRX Stage 4
Midnight Black
Add up the fuses that are on the amps and then use an fuse bigger than that.
blkwrx02 is offline   Reply With Quote
Old 12-22-2005, 09:23 PM   #6
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
The fuses that are inline with the main power wire or in a power distro block are fusing against fires from the wires melting. You fuse based off the gauge of the wire. Go to www.BCAE1.com and I think it was topic 14 Fuses.
offset
offset is offline   Reply With Quote
Old 12-22-2005, 10:19 PM   #7
WRblueX_Guy
Member#: 53247
Thanks guys.
offset, I was reading the fuse section the other day, but I'm not sure I quite understand it. It says "Any fuse rated at less than ~150 amps is sufficient to protect a 4g wire and the vehicle (if the 4g wire is longer than ~15 feet long, you may want to limit the fuse to ~125 amps)." Then for 4 guage wire, it says the recommended maximum fuse size is 125A.
What would happen if I tried to use a 150A fuse with my 4 gauge wire?
Old 12-22-2005, 11:02 PM   #8
mikeyg
Member#: 86497
04 STI
Default fuse size
I'd go with a 125 amp or a 150 amp anl. I don't think it will make too big of a difference. To be really accurate, you would need to find out the potential current draw of your amps using a conservative efficiency percentage. Then choose a wire whose rating accomodates this current. I think 4 ga is comfortable at about 125 amps. Then choose a fuse that is rated around the upper end of the wires current capacity. So when adding the new amp determine the cumulative current draw of both amps. Of course, the lower the fuse, the more sensitive it will be to blowing, which is a good thing because this main fuse is protecting the battery from a fire that could result from the wire overheating. For that reason, it should be as close as possible to the battery. If you think your amps will draw a max current that is rated higher than the power wire, you'd need to get larger wire. I doubt that's the case here though. I would also get a fused distrobution block to separate the power to the amps. AGU fuses should be fine here. Good Luck
mikeyg is offline   Reply With Quote
Old 12-23-2005, 12:23 AM   #9
Freon
Member#: 88322
2009 BMW 135i
I would not run more than a 125amp fuse on 4 gauge wire. I'd even try not to run more than 100amp just for some margin. If you really are pulling 125amps, you should upgrade to 2ga or better.
Let's see... 85x2, other two channels doing nothing, and 260x1, right? So not even 500w total RMS! 80A is plenty.
Don't calculate by adding up the fuses built into the amps. They're usually on the large side. Calculate for your whole system power.
Freon is offline   Reply With Quote
Old 12-23-2005, 01:25 AM   #10
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Possibly nothing. But then again you could possibly not run any fuses and be fine. Remember that fuses aren't supposed to be limiting power under normal circumstance; only in case of a severe problem. If a wire gets pinched and grounded to the cars metal or an amp goes haywire and starts pulling obnoxious amperage it could cause the insualtion to melt and possibly start a fire with the interior carpeting. I think 125A would definately be as big as you should go, but given your amps I think a 100A fuse would be fine and more telling of problems if it were to blow.
offset
Old 12-23-2005, 03:37 PM   #11
HolyMahwah
Member#: 53936
2008 Leg GT
2004 WRX -> Billy-fied
Offset and Freon are right. As stated, the fuses on the amps themselves are for max power draw, not continuous. The amount of actual power that the amps are putting out are your best guide to how much juice you need:
85x2 + 260x1 = 430W
assume 50% efficiency, so 430 / 0.5 = 860W draw from battery/alternator
860W / 14.4V = 59.7A being conducted in wire
Therefore, 80A or 100A fuse is fine.
HolyMahwah is offline   Reply With Quote
Old 12-23-2005, 04:06 PM   #12
WRblueX_Guy
Member#: 53247
Awesome, thanks guys.
I think I'll stick with the 80A fuse I have for now, unless it blows. Does anyone know if they make/where I could buy a 100A AGU fuse? Or do they only make 100A ANL? If so, I would have to get a new fuse holder.
Old 12-24-2005, 12:22 PM   #13
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
If you had to go bigger than 80A you would want to step up to a good ANL fuse holder.
offset
Old 12-24-2005, 01:28 PM   #14
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
fuse's blow! get a circuit breaker. 140A, i have had a fosgate one for 3 yrs now, i think it popped once, all you do is re-set it.
jam69007 is offline   Reply With Quote
Old 12-24-2005, 01:51 PM   #15
i_dream_of_STI
Member#: 85530
05 Saab 9-2x Areo
Arctic Silver
Default 1+ for the circuit breaker style fuse
Thats what i am using.. only use fuses internally in the amp and one right before the sub amp.
-Jason
i_dream_of_STI is offline   Reply With Quote
Old 12-24-2005, 03:52 PM   #16
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
Actually the inline fuse should be at the maximum rated amperage of the wire. If your pulling more amps through the wire than the wire can handle it will melt the coating on the wire allowing it to short out, possibly causing a fire before the fuse even blows. 4 guage wire is more than enough for your setup. Just leave the current fuse in there. I was running my 1800w system through my 0 guage kit with an 80amp fuse for about two years with no problem.
Honest Bob is offline   Reply With Quote
Need some help figuring out what I messed up. Iwalani Pre-2002 Factory Turbo Powertrain 20 08-31-2007 03:54 PM
Need help figuring out what is wrong with car roybfr Factory 2.5L Turbo Powertrain 5 07-17-2006 01:06 PM
Need help figuring out what to wear to a theme party Briman2021 Off-Topic 18 06-02-2006 02:49 PM
Need help figuring out what car I saw yesterday... kilonad Off-Topic 12 07-31-2005 11:47 PM
What size fuses for an 800 watt rockford amp? Dakken Car Audio, Video & Security 4 10-14-2002 07:50 AM
Message Board Statistics All times are GMT -4. The time now is 01:21 PM.
