Old 12-22-2005, 09:06 PM   #1
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
Default would this rim fit 255/45/17 nitto555rs under the fenders of my bugeye?
I am looking at these rims. Would they be able to mount 255/45/17 nitto 555r extreme tires? Then once they are on, (which im sure will work) will they then fit under my fenders? I drive an 02 WRX lowered really low on tein suspension. I have the tires already, and just need to figure out the right offset and width! Thanks!!!
here are the numbers
02 WRX
really low
17" x 7.5 wide
45mm offset
255/45/17 tires
Thaniks!!! Merry christmas!
jared nelson is offline   Reply With Quote
Old 12-22-2005, 09:07 PM   #2
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
Old 12-22-2005, 09:07 PM   #3
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
http://cgi.ebay.com/ebaymotors/17-BL...23475448QQrdZ1 there is the link to the ebay auction
Old 12-22-2005, 09:40 PM   #4
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
wrong size tires
wheels too skinny
car probably too low
rex n effect is offline   Reply With Quote
Old 12-22-2005, 10:08 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by rex n effect
wrong size tires
wheels too skinny
WAY-WAY wrong size tire....
Old 12-22-2005, 10:12 PM   #6
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Even if they fit, your terrible WRX gearing just got worse.
waktasz is offline   Reply With Quote
Old 12-23-2005, 04:24 PM   #7
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
terrible WRX gearing is a very relative thing. I really am ok with it, and wouldnt mind it being alittle higher.
these tires are like 1.2 inches taller than stock.
Old 12-23-2005, 05:24 PM   #8
rex n effect
Member#: 15289
02 wrx pollen silv
which means your car will be .6 inches HIGHER. Why on earth would you want that?
Old 12-23-2005, 06:11 PM   #9
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
which then means ill get under my car, and lower my tein coilovers .6 inches.
Old 12-23-2005, 06:43 PM   #10
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
Ok, you say your car is already pretty low.
which most likely means very little suspension travel as is.
lowering the car even more will allow for even less.
you'd most likely want an 8" wheel to fit 255s.
you might want to look into something with a little higher offset +48 should be better.
the +45mm might be pushing it.
Plus with the added height you will need to make sure the tires are indeed inside the fender and not "flush"
Good luck and I'd suggest something of the 17x8 +47 thru +50mm offset range.
WRX8XB is offline   Reply With Quote
Old 12-23-2005, 06:48 PM   #11
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
I will not be getting those rims. I want to go as wide as 8 or 8.5. I dont know much about it, but I really like the idea of doing taller tires. This thread, http://forums.nasioc.com/forums/show...8&page=1&pp=25 is a really good one.
Old 12-23-2005, 07:13 PM   #12
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
That tire is to tall to fit unless you raise the car way up. It will rub the front fender liner and your rear fenders unless you have those rolled out.
afpdl is offline   Reply With Quote
Old 12-23-2005, 07:22 PM   #13
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
taking .6 inches away from the distance inbetween the tire and the liner is not going to do that my friend, im sorry.
Old 12-23-2005, 07:46 PM   #14
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Are you low or not? With 245/45/17s any lower than 13.5" rideheight (which isnt that low) and 550lb springs I rub the front fender liners.
Old 12-23-2005, 11:23 PM   #15
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
my car is on teins, i dont know exactly what it is at, it looks like this. ..
I can go lower too, and my spring rate is adjustable, so I can tighten it to obnoxiously tight levels.
Old 12-24-2005, 01:08 AM   #16
rex n effect
Member#: 15289
02 wrx pollen silv
with tires that wide and tall, you might want to think about RAISING your coilovers. Also, your car will be noticeably slower. Your spring rates are not adjustable, unless you get new springs.
Old 12-24-2005, 06:59 AM   #17
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
adjustable spring rate? what tein's are you running on? dual height adjustable flexs? that can't be, the springs are too soft on those, tein ra's? those aren't dual height adjustable. re's? wait, those don't have adjustable spring rates as well
petawabit is offline   Reply With Quote
Old 12-24-2005, 04:59 PM   #18
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
adjustable damping force.
Old 12-24-2005, 05:39 PM   #19
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
thought you were referring to those:-P flex? a 17x8 or 17x8.5 in +48 should be fine. I think best bet is a +50 offset
Old 04-18-2006, 03:25 PM   #20
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
Hey everyone just a quick bump... I got rims. They are Rota attacks 17" with +48 offset. I might need to get new tires, because these rims are only "7.5 That means these tires might not being mounted on such narrow rims. Idunno. For the next little while, I will be running around on a set of snow tires, so Ive got some time to decide on maybe buying a set of new tires, or getting a new set of rims that are wider.
Any input?
Old 04-18-2006, 03:26 PM   #21
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
oh, and I am pulling my plastic fender liners out.
Old 04-18-2006, 07:22 PM   #22
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
bump s
Old 04-19-2006, 07:11 AM   #23
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Pulling your plastic fender liners out?
Those tires should NOT be mounted on a 7.5" wide rim. At the MOST you might be able to do a 245/45-17, but even that is really too wide for a 7.5" wide wheel. I'd suggest 225/45-17 and be done with it.
Old 04-19-2006, 10:25 AM   #24
stidailydriver
Member#: 69650
06 sti
black w/gold
^^agreed...don't do it, stick to the 225s, the 255s are WAY to wide for a 7.5"
*and before all the nay-sayers come in and argue, i know it can be done, but should it?*
stidailydriver is offline   Reply With Quote
Funky noise from the front of my bugeye Fireguy615 Brakes, Steering & Suspension 0 12-15-2009 09:17 PM
Can a Forester fit 255/45-17? Gonzalo_C Tire & Wheel 1 02-17-2009 09:06 PM
Noticed a loud air leak from under the center of my hood JConnX Texas Impreza Club Forum -- TXIC 9 04-08-2008 11:34 AM
the evolution of my bugeye (new rims on now) nutzkicker617 Member's Car Gallery 29 08-31-2006 07:56 PM
('93-'01) dirt under the edges of my wing bluey Impreza Forum 3 04-17-2001 10:30 PM
