Old 12-22-2005, 11:22 PM   #1
SketchINoc
Member#: 87370
2005 WRX,Soon to be
EVO9-94 toyota4x4 project
Angry my stage 2 is running horrible!
Greetings.
My 05 WRX is running very slugish, but I am hitting target boost according to my Accessport. How does the Accessport messure boost? Is it accurate? Today I popped my hood to check for leaks at a gas station, and I noticed a small amount of smoke coming from the turbo. It smelled like burnt oil.
Mods:
05 WRX - 5mt - 36k miles - Cobb Accessport running stage 2 91 cal 1.30, helix uppipe, helix downpipe, custom intermidiate pipe, K&N drop in.
The oil is changed every 3k miles with mobil one 5w30.
What is going on with my car?
Thanks for the help!
SketchINoc is offline   Reply With Quote
Old 12-22-2005, 11:26 PM   #2
Davenow
Member#: 23676
sounds like you are either VERY rich, or the turbo is dead/about to die
If you had proper gauges you would already know or have a much better idea (thats my way of saying get some gauges so you know whats going on with your car)
Actually it looks like you are saying the smoke was coming off the turbo itself like under the hood
This is a classic symptom of a bad turbo. Blown seals.
Old 12-22-2005, 11:35 PM   #3
JRSCCivic98
Member#: 67080
How long has the car been on Stage 2? If you just recently installed the parts the burning off could be oil or wd40 if you used it for the bolts. What we're missing here are a few things...
How long has it run like this (sluggish)?
What was the last thing you changed before it started doing this?
Did you remove the turbo to install uppipe? (If so, did you install both of the crush rings on top and below the oil fitting on the banjo bolt?)
Are you sure you're not running some sort of crappy realtime map on top of your base. (Do a reset function on the AP and see how your car behaves after that.)
If you didn't install the AP yourself, are you sure you're on the right map?
Answer those questions and we could probably help a little more.
JRSCCivic98 is offline   Reply With Quote
Old 12-22-2005, 11:39 PM   #4
SketchINoc
Member#: 87370
2005 WRX,Soon to be
I did the uppipe/downpipe/intermidiate pipe about 25k miles ago. I flashed stage 2 about 4-6k miles ago.
The car has been running slugish for the past couple of days.
When I did the uppipe, I did not remove the turbo.
I installed the AP myself. I am %100 positive I am on the right map. (base = stage 2 cal 91 v1.30)
I will try the reset function.
thanks.
Old 12-23-2005, 09:39 AM   #5
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
so you ran a TBE + up for 20k miles with no EM & crappy cali gas
kevin2.5rs is offline   Reply With Quote
Old 12-23-2005, 09:44 AM   #6
TopKatz
Member#: 36793
04 WRX
Try running the stock map, and or un-installing the AP and see what tha t does.
TopKatz is offline   Reply With Quote
Old 12-23-2005, 09:45 AM   #7
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
I will try the reset function..
reseting the ap will do nothing for a blown turbo.
I think its time for stg 2.5
Old 12-23-2005, 12:58 PM   #8
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
I have an 05 and I blew my turbo too, she goes in after new years for warranty repair The turbo started smoking around 3500 miles.
Devil Catless TBE
Cobb AP stg II
6k miles
EagleRockWrex is offline   Reply With Quote
Old 12-23-2005, 01:32 PM   #9
vlady
Member#: 77997
dirty blue
Devil Catless TBE
Cobb AP stg II
6k miles
I hope you're taking off your catless tbe. I can't see a dealer replacing a turbo when you have completely modified the exhaust. Good luck!
vlady is offline   Reply With Quote
Old 12-23-2005, 02:20 PM   #10
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Way to encourage warranty fraud there buddy....
Acostafan is offline   Reply With Quote
Old 12-23-2005, 03:57 PM   #11
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
My car has been smoking since before I put the catless TBE on, southcoast is warranting it.
Plus, how could an exhaust blow a turbo ? its after the turbo, the turbo just went south and I have noticed alot of 04/05's have been doing the same thing
Old 12-23-2005, 04:19 PM   #12
Bundyboyz
Member#: 32764
2003 WRX with 91K
New Motor & Paint WRB
^^ smiles... and awaits for someone else to bash
Bundyboyz is offline   Reply With Quote
Old 12-23-2005, 05:21 PM   #13
InfamousDX
Member#: 25413
lol.. "how could it blow a turbo, it's after the turbo"... wow.
Stage 2 Rex running rough and can't find the cause Six Stars Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-25-2006 11:59 AM
Stage 2 - Is my boost ok? WrexT AccessPort 7 07-08-2006 04:53 PM
Cobb stage 2 STi run at the track turbo tecnica Proven Power Bragging 19 06-23-2006 08:18 AM
Shocked--Stage 2 Cobb run CoolRex Proven Power Bragging 22 07-27-2005 01:41 PM
Anyone with Cobb stage 2.5 running w/o Fuel pump? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-07-2004 06:52 PM
