Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Closed Thread
Old 02-05-2006, 12:20 PM   #51
capecod_wrx
Member#: 43277
'08 VDub R32
Originally Posted by Peaty
If you went in that far I don't think you had them, mine were right up by the top of the hole. Since your car is running well I don't think they are in the system anywhere.
thanks for the reassurance peaty... my wife also has an '04 FXT. i'll be checking her car soon for a comparison.
capecod_wrx is offline
Old 02-05-2006, 10:36 PM   #52
rim3
Member#: 62494
2004 Forester XT
Originally Posted by hondaslayer
Mine was done about 2 weeks ago and the idle still has the Suby shake but it is not as viloent.
And at 33k just let the dealer do it. You are still under warranty.
Not a fan of the dealer, if you haven't seen my rants yet.
Just did mine this weekend. I agree, the shake isn't as violent. Both filters fell out and were easy to find. In all the pics, the top of the filter just looked like oil or something, but that is actually what the filter looks like. Before hooking the MAF sensor back up, I started the engine and let it idle to check for leaks. I also removed the resonator while I was at it. After assembling everything and starting the engine, the Check Engine light was on and the CRUISE light was flashing. Took it out for a spin to check things out and wasn't too impressed. I unhooked the battery to reset the ECU and the problem was all cleared. SHE'S BACK TO HER OLD SELF!!!! Thanks Peaty.
Does anybody have a clue what the blinking CRUISE light meant?
rim3 is offline
Old 02-05-2006, 11:00 PM   #53
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
It meant your CEL was on and you should have had it scanned before you cleared the ecm memory
Hondaslayer is offline
Old 02-05-2006, 11:22 PM   #54
rim3
Member#: 62494
2004 Forester XT
Could I have possibly thrown the ECU off by starting the engine with the MAF disconnected? If it is actually a valid CEL and there is a malfunction, then wouldn't it come up again? I've put 150+ highway miles on it since then and it is still working well.
rim3 is offline
Old 02-05-2006, 11:24 PM   #55
Hondaslayer
Member#: 4562
1995 Legacy LSi
Yep.
Probably the cause, but it's always a good idea to get the code scanned before clearing the memory. You never know .
Old 02-05-2006, 11:29 PM   #56
rim3
Member#: 62494
2004 Forester XT
Yep.
I can't argue with that, but circumstances didn't allow.
How do I post pictures? Is there a size limit or will it automatically downsize images?
rim3 is offline
Old 02-13-2006, 08:31 PM   #57
yungster1972
Member#: 71827
2004 Forester STi
Java Black Pearl
I dont know if this is odd or not but my 04 FXT it didnt have any filters. Just thought I would throw that out there. -ED-
yungster1972 is offline
Old 02-13-2006, 09:19 PM   #58
pleiad7
Member#: 71056
MY04 Forester XT
You can't attach pictures here, you have to host them someplace like photobucket.com and link them.
pleiad7 is offline
Old 02-14-2006, 09:25 PM   #59
drew21180
Member#: 49684
2004 Forester XT 5MT
Thanks a mil, Peaty. How did you find out about this? Trial and error?
I just did this, way easier than I though. However, one problem I ran into was that I didnt have a long enough ratchet extension. I was still able to loosen the bolt but unfortunately touched the wrench handle to the positive battery terminal and shorted out. I just removed the negative terminal and continued, but scared the *%!@ out of me for a second.
drew21180 is offline
Old 02-14-2006, 10:31 PM   #60
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
There is a TSB on this it's in the very first post.
You have to be real careful with making the battery spark. I've seen one blow up on a friend when he was testing for a spark on a sparkplug cable close to the battery. Blew the top right off the battery. Very scary.
Peaty is offline
Old 02-19-2006, 04:20 PM   #61
capecod_wrx
Member#: 43277
'08 VDub R32
i checked my wife's FXT this morning when i changed the oil. sure enough - both filters were there - (unlike in my FXT) - and they had both dropped.
they were a pain to get out - but in the end i was victorious. the car idles much better and runs smoother too.
Old 02-26-2006, 01:46 AM   #62
SubaruCO
Member#: 33566
Pulled mine out yesterday. Both filters were there and had fallen out of the banjos. Can't say it runs any differently now, but peace of mind is a good thing.
Oddly enough this is the first time I've put a wrench to the FXT in a long time. It's a good thing I have the race car to work on to get my mod itches worked out. No need messing with the daily transportation.
SubaruCO is offline
Old 02-26-2006, 02:31 AM   #63
pleiad7
Member#: 71056
MY04 Forester XT
We finally got around to performing this minor surgery on Subed today. One of the filters was still in the bolt, the other one had dropped (but was easily retrieved with a pair of needle nose pliers).
pleiad7 is offline
Old 03-11-2006, 04:53 PM   #64
geoffrey raiser
Member#: 59578
2004 Forester XT
Thumbs up
Thanks, Peaty! I found 1 filter had dropped, 1 was still in the banjo bolt. The dropped one came out easily with a 3-pronged grabby thingy tool. I reused the washers, torqued the bolts to 22 ft pounds, no leaks.
The motor is now noticeably quieter and smoother at idle. Thanks again for bringing this to our attention!
Geoffrey
geoffrey raiser is offline
Old 03-30-2006, 05:43 PM   #65
bo9877
Member#: 31452
1995 Legacy L FWD
Power Windows & Locks!
Originally Posted by ez bturbo
sparkplugs were changed 3k miles ago, didnt fix the problem.
Just saw this....
What brand plugs did you install? The Champions that come on the Indiana-built cars are crap to begin with, and if you replaced them with the same type of plugs it could still cause problems. Try swapping them out with a set of NGKs and then resetting the computer...most of the time that alone will fix the hesitation experienced in the Baja and last-generation Legacy/Outback.
bo9877 is offline
Old 03-30-2006, 05:50 PM   #66
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
F-XT's come with iridium NGK plugs, it's the NA 2.5's that came with champion AFAIK
Peaty is offline
Old 03-30-2006, 08:29 PM   #67
bo9877
Member#: 31452
1995 Legacy L FWD
Yes, but the guy I responded to has a Baja Turbo, which came with champions.
bo9877 is offline
Old 05-18-2006, 12:46 AM   #68
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
does anybody have any pics of there Forester?
bhhamblin is offline
Old 05-18-2006, 02:03 AM   #69
dizizjake
Member#: 56879
2015 WRX STi LTD
CRYSTAL WHITE PEARL
Here's mine....
dizizjake is offline
Old 07-24-2006, 09:16 AM   #70
Seayak
Member#: 52687
2004 Forester XT 5M
Peaty - you are THE MAN! I did this yesterday and I have my great car back! No more hesitation, stuttering, etc... I should've done this MONTHS ago! FYI - both filters had dropped down, just like everyone else's.
I even had a printout of the TSB for my dealer to look at - they did some diagnostics and said my car didn't need the fix! Probably took them longer to test it than it did for me to fix it ;-)
Seayak is offline
Old 08-24-2006, 12:23 PM   #71
destroir
Member#: 120582
2004 Forester XT
Angry
I did this fix but still have hesitation problems. It hesitates during "mild" acceleration between 2500 and 3500 RPMs... after that it's smooth. Not sure what this could be and when I took it to the dealer the last time, they said that they didn't notice anything! I'm certainly not imagining this (everyone that's ridden in my car notices it too) so I'm going to take the dealer for a ride next time around. Removing the filter almost seems to have made it worse! I'm thinking maybe spark plugs?!?
destroir is offline
Old 08-24-2006, 02:36 PM   #72
SirWilliam
Member#: 64805
2008 SG6 Model D
BlueRallyWorld
A grounding kit could help. How many miles? When did you change your plugs last? Do you have an aftermarket stereo system?
SirWilliam is offline
Old 08-24-2006, 05:31 PM   #73
ne0stai2dust
Member#: 65964
1994 Mazda MX-5
you can check out www.subaruforester.org. all the guys you see in here are members of that forum.
I still need to do this TSB on my car as well.....
ne0stai2dust is offline
Old 08-25-2006, 11:17 AM   #74
destroir
Member#: 120582
2004 Forester XT
Question
It only has 12,000 kms (about 7500 miles). Plugs have never been changed. Factory Stereo. I only bought it about 6 months ago from a dealer that had it "sitting" in the showroom for a year and a half so when I bought it, it only had 350 kms!
Not trying to be a smartass but why would a grounding kit help?
destroir is offline
Old 08-25-2006, 07:34 PM   #75
brett s
Member#: 44606
2016 Forester XT
It's an ecu thing, emissions related - that's the rpm range where it transitions between open & closed loop. A reflash can do away with it but it's not hurting anything - it's just mildly annoying. You'll get to where you either ignore it or avoid it by using more throttle...
brett s is offline
Closed Thread
04 XT owners FYI Peaty Forester Forum 0 11-19-2005 05:38 PM
Any NJ XT owners Ibizan Forester Forum 0 06-07-2003 12:05 PM
It's official, I'm an XT owner! Ibizan Forester Forum 33 06-03-2003 11:03 PM
('93-'01) Calling all XT owners Kevin Thomas Impreza Forum 3 05-21-2001 06:41 AM
Any XT owners out there? I have a [Q] Peaty General Forum Archive 0 10-22-2000 06:39 PM
