Old 12-23-2005, 03:43 PM   #1
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
Default DCCD wiring on a 04 sti 6spd
I have a 02 wrx and put the 6 spd from a 04 sti in my car.i ran it w/no dccd control for a while, now im installing the manual dccd controller spiider sells here on nasioc.
I cant seem to find the wires on the tranny for the dccd controller. in the diagram i have it says that it is a white clip w/2 wires(one red w/white one yellow w/red). I cant find this plug, anyone know where i should be looking for it?
-mikey
mcu81 is offline   Reply With Quote
Old 12-23-2005, 06:38 PM   #2
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
im thinking that its the wires that are on the white plug there...........anyone have any ideas?
-mikey
Old 12-23-2005, 08:54 PM   #3
Spiider
Member#: 13680
Hey, It comes out of the rh (passenger side) side of the tranny. It is the wire coming out of the top right of the pic on the side of the tranny away from us that looks like it goes into the white plug. It is probably a black wire and a red wire on your tranny.
Good luck with the install, I'm still loving the prototype I made that is installed in my car. We've had a good amount of snow here and it really makes a big difference in traction. Just don't foret to change it to 0% it if you want to actually be able to turn into a parking spot.
Spiider is offline   Reply With Quote
Old 12-23-2005, 09:00 PM   #4
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
ok that works i got it, but will polarity matter? if i hook it up backwards will 0% be fully locked and 100% be fully open?
thanks again
-mikey
Old 12-23-2005, 09:30 PM   #5
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
if it helps, on my plug i have green w/white stripe and green solid into that white connector.
-mikey
Old 12-23-2005, 09:40 PM   #6
Spiider
Member#: 13680
No, polarity doesn't matter. Just hook up the two wires marked "D" to those two wires.
I'm sort of stumped on the color changes. So far thats 3-4 different wire color combo's I've heard of for different tranny's.
I have red and black on mine, you've got this green/stripe and green solid combo, plus the one in the wiring schematic is red/white stripe and yellow/red stripe.
Mine is a JDM, your's is USDM? The schematic I gave you with the controller is for USDM actually but they shouldn't change the wire colors so much IMO.
Maybe its based on year as well. Mine's a JDM late '03 serial number.
Old 12-23-2005, 09:42 PM   #7
Spiider
Member#: 13680
Geez, you have the fittings for a tranny cooler. Lucky guy, is that actually a JDM Spec C tranny?
Mine has them directly connected to each other with a single line.
Old 12-23-2005, 09:49 PM   #8
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
haha
nah, no spec c tranny, the above pic i used is from a 6 spd gruppe S sells, i just needed a pic for a reference. I have a 04 USDM 6 spd........basically though, theres 2 plugs white and black, and a third set of 2 wires that come up and for a clip at the top of the tranny, under my intercooler. I think ima just tap the green w/white stripe and green wire up there.
I am hoping the white connector is the one that goes to the far side of the tranny, i cannot see up there for anything, nor get my fat hand up there to feel it. I also dont have my reverse lights hooked up, which i think is the other black connector!
-mikey
Old 12-23-2005, 09:52 PM   #9
Spiider
Member#: 13680
Cheers, shoot me an email once you have it hooked up, or if you need any more install tips.
-Jeff aka Spiider
Old 12-24-2005, 03:37 AM   #10
Hiroki Tada
Member#: 8048
Jeff, care to wire a controller up for me? heh heh heh...
Hiroki Tada is offline   Reply With Quote
Old 12-24-2005, 07:00 PM   #11
Spiider
Member#: 13680
Hey Andy! If you need a controller I have one sitting on top of my fridge ready to go. Iain said you were getting the Neetronics one...
Old 12-25-2005, 07:58 PM   #12
hmhaga
Member#: 54991
1998 '15 Outback 2.5
Polarity DOES matter! You have to get the GROUND-side of the DCCD-controller right, follow the wiring from the DCCD ECU to the connector on the gearbox (6 pin connector, also used for neutral and reverse)
I have the Neetronics DCCD controller in my car, HIGHLY recommended!
hmhaga is offline   Reply With Quote
Old 12-26-2005, 08:14 PM   #13
Spiider
Member#: 13680
We are not talking about the Neetronics unit. We are talking about the one I produce for sale here and on eBay. It uses the "homemade DCCD controller" schematic from last years thread on the topic.
My controller needs +V, -V and two wires to the DCCD coil, nothing else.
The polarity of the power supply matters but nothing could go wrong even if you wired that up backwards because I put a diode on the input to protect against reversed supply voltage and also for safety due to back emf. If you hook up power backwards it just won't do anything.
Old 12-26-2005, 09:38 PM   #14
subalou1
Member#: 57966
2002 wrx Sedona Red
[email protected], best trap 131
spiider, sounds cool, does it use the stock switch? I have the switch and everything but nothings hooked up.
Thanks
subalou1 is offline   Reply With Quote
Old 12-27-2005, 10:42 AM   #15
Spiider
Member#: 13680
It can use the stock switch if you already have one. I also provide one with the kit that installs under the ebrake lever in the console.
Old 06-05-2008, 01:08 AM   #16
wrxwagon253
Member#: 125620
05 3076R Wagon
B5 S4 w/ Stg.3 RS6 kit
Spiider makes a great product and I highly recommend them. Customer service is great and very fair prices.
wrxwagon253 is offline   Reply With Quote
04 STi 6spd leaking because of axles help o2sys Transmission (AT/MT) & Driveline 36 08-12-2007 09:32 PM
Dccd Wiring into my 04 wrx w/ a 6 speed swap. snowcrzy Transmission (AT/MT) & Driveline 11 10-16-2006 12:04 AM
Rs W/ 04 Sti 6spd Short Shifter topguneagle1 Transmission (AT/MT) & Driveline 8 10-05-2006 02:18 PM
WTB: FULL WIRE HARNESS FOR 04 STI including DCCD NotoriousD Private 'Wanted' Classifieds 5 02-27-2006 08:43 PM
Currently swapping 04 sti 6spd into 02 wrx, some short notes on the swap mcu81 Transmission (AT/MT) & Driveline 7 02-02-2006 04:02 PM
