Welcome to the North American Subaru Impreza Owners Club Sunday August 31, 2014
Old 12-23-2005, 03:25 PM   #1
subeesteve25
Guest
Member#:
Default second oil change
ok i got my first oil change at like 3k miles from a oil stop drive thru place on my 05 wrx. they put in 5w-30 oil. Now i have 7k miles on it and am ready for my next oil change. Where should i have it done and what oil do u all suggest. I just wanna do whats best for the car. btw i have a tbe catless. thanks.
Old 12-23-2005, 04:05 PM   #2
MartinD
Member#: 57231
Do it yourself...it depends if you want to make the switch to synthetic or not...tons of threads....look around meng
MartinD is offline   Reply With Quote
Old 12-23-2005, 05:08 PM   #3
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Do it yourself, it's extremely easy to do, and gets you familiar with the car.
Personaly I would stick with dino 10w-30 oil until the switch to synthetic at 15k, but that's just me. As far as dino oils go, I'm a big fan of Castrol GTX stuff.
eltrouble is offline   Reply With Quote
Old 12-23-2005, 05:38 PM   #4
jmax
Member#: 103196
06 TRIBECA
SILVER
Default subeesteve25
Wait till you have at least!12 to 15000mi. on it.Takes time to break in motor. Ive had two,One had 8000mi other had about 14000mi THe one with lessor milage seemed to breakin longer ,based on how car ran.It was ok but one with more milage ran quiter and smother.BE patient.It's a great motor it should last you a log time ,used Mobil 1 5-30w.Good luck.
jmax is offline   Reply With Quote
Old 12-23-2005, 05:47 PM   #5
Crashton
Member#: 3808
2005 Forester XT!!!
Crystal Gray Metallic
Subaru Stars
Like has been said already, it's a bit too early to switch to synthetic. I'd go at least one more change with dino oil. Then use whatever you're fond of. For me it's Mobil 1, 5W30.
Crashton is offline   Reply With Quote
Old 12-23-2005, 06:18 PM   #6
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
5w-30 is nice, but I think for californian weather it's a bit too thin.
Old 12-23-2005, 06:38 PM   #7
subeesteve25
Guest
Member#:
they put in chevron oil 5w-30, whats that. should i use that again?
Old 12-23-2005, 10:06 PM   #8
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
Def do it yourself, easy as pie and it's a great piece of mind knowing some knumbskull did not screw up your car.
kero is offline   Reply With Quote
Old 12-24-2005, 12:29 AM   #9
subeesteve25
Guest
Member#:
what oil should i use
Old 12-24-2005, 02:46 AM   #10
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Read the stickys at the top of the forum, that's what they are there for!
http://forums.nasioc.com/forums/show...hreadid=499177
Second oil change..after stage 2 mjjantz General Community 10 06-09-2006 06:23 PM
Metal shavings on second oil change?!!!! progresr Factory 2.0L Turbo Powertrain 5 10-05-2003 07:41 AM
oil light came on for a second after oil change... is this normal? Poe Factory 2.0L Turbo Powertrain 3 01-28-2003 10:07 PM
