Old 09-10-2001, 05:47 PM   #1
SYMS GT
Member#: 427
'91 SS Legacy EJ257
DOHC/18g/FMIC/V.8 6spd
Question Movement of climate controls..who asked?
Sorry, who was it the PM'd on the movement of the climate controls for the Legacy? I some how lost your message.
SYMS GT is offline   Reply With Quote
Old 09-10-2001, 09:56 PM   #2
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default ABOUT 6 MONTHS AGO...
...I asked someone...I believe it was you when I saw the pics of your interior...I was thinking of moving the climate control panel to the bottom so I can install the Apexi Super AFC on the top of the dash! Is it easy to do?
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 09-11-2001, 01:14 AM   #3
AWD_SUB
Member#: 9867
1998 Legacy 2.5 GT l
Drk Plum
Question
Matt, I really need to talk to you about upgrades. can you let me know the best way to get back at you?
AWD_SUB is offline   Reply With Quote
Old 09-12-2001, 08:11 PM   #4
SYMS GT
Member#: 427
'91 SS Legacy EJ257
Default Cut it up...really...
For the movement of the climate controls you'll have to be dedicated to it. It takes some snipping, cutting, sanding, and glueing... Wiring all depends on what you're installing in it's place. Thanks BTW for noticing...must mean I did a good job of making it look OE
First off you get down to the bare bones of the car. Removing all the center console area leading up to the heater vents. All this is done with a philips srew driver and some pop clips for removal.
-There are 2 scews under the ash tray pointing upward.
-When you get to the vents, this portion should just pop out, give it a good pull. Don't jerk on anything too hard, that's how things break, plus the hazard switch is hooked to the back!!
After inside you'll see the 4 screws holding in the climate controls in. Remove these and the unit will be able to be removed from it's resting place. (Don't drop the screws, these can easily bury themselves under the dash) Once out you'll see 2 wire bundles and one detent cable for the heat gradient connected to the unit, unclip the 2 bundles.
The tricky part is unclipping the C-clip retaining the detent cable. It can be done with a small flat screwdriver and some finese. Again make sure not to lose any parts. After that the whole unit should be sitting in your hands. FYI: This is now the time to install new bulbs in the unit if needed...I forgot
Everyone still with me?? IF so continue down to the stereo and DIN sized pocket. Remove all of this.
Now for the trully dedicated. Snip off the 4 mounting holes!! Now the fun begins. Start sanding bits at a time.......till it fits in the new location. Constantly trial fitting the unit.
Anyone still with me??? If so I'll continue.......
Old 09-12-2001, 10:48 PM   #5
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default I AM HERE
Keep it coming!!!
CRAZY KEN
Old 01-02-2002, 04:02 PM   #6
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
SYMS GT,
Whatever happened to the explanation? My question isn't so much about filing and sanding but how you managed to mount the heater controls once they were shaved to fit in the din-sized opening. I'm looking to move the controls out of the way to fit three 2 1/16 inch gauges in the opening. I already have a template for this which fits perfectly and am ready to cut and extend the heater wires to accomodate the move
Please elaborate. Thanks.
Jason
2.5GT is offline   Reply With Quote
04/05 HVAC controls with Auto Climate COntrol murderedoutrex Interior/Dressup/Audio & Security 1 06-17-2008 02:44 AM
Is the auto climate control lowest setting of 65 degrees F too hot for you? AardvarkWRX Interior & Exterior Modification 22 12-18-2007 12:45 AM
05-07 hvac control climate control wrxmase Interior/Dressup/Audio & Security 6 04-16-2007 08:36 PM
Control dual climate control from one knob? pgrey Electrical & Lighting 0 09-16-2004 07:16 PM
Color of WRX gauges, climate control and stereo? rp2000r Newbies & FAQs 9 07-28-2004 04:55 AM
