Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 12-23-2005, 10:54 PM   #1
hilfiger4you
Member#: 93015
02 wrx
black
Default Where is fuel filter located in STI
I am going to the dealership to change my fuel filter. They want to charge 75 dollars which sounds okay. I was wondering where is the STI fuel filter located? The service man said it is in the lines.
PLease advise guys
thanks
hilfiger4you is offline   Reply With Quote
Old 12-23-2005, 11:08 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...in the tank, I thought
Uncle Scotty is online now   Reply With Quote
Old 12-23-2005, 11:21 PM   #3
hilfiger4you
Member#: 93015
02 wrx
black
Wow then it must cost even more than, cause my friend had to have his tank taken off and it took a few hours since they had to remove tons of parts under the car for the tank to drop out.
Old 12-23-2005, 11:58 PM   #4
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
The fuel filter is located in the tank....it's not a normal maintenance item
You can gain access to the tank by removing the back seat bottoms. You should not have to drop the tank. The process should take no more than 30 minutes
RexyGirl is offline   Reply With Quote
Old 12-24-2005, 04:27 PM   #5
hilfiger4you
Member#: 93015
02 wrx
black
I thought there is a fuel filter located in the engine bay. At least that was what I heard from a few people.
Old 12-24-2005, 06:53 PM   #6
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
The service guy should get back to you after the technician tells him that it isn't a normal fuel filter replacement.
-paK +1
Pakin is offline   Reply With Quote
Old 12-25-2005, 04:59 PM   #7
hilfiger4you
Member#: 93015
02 wrx
black
I know the fuel sensor is in the trunk where you have to take it out by taking out the backseat. however, on nasioc I read there is a fuel filter located in the engine bay. So which one should I change? I am confused since people are saying different things.
Old 12-25-2005, 06:35 PM   #8
firedust
Member#: 38795
2003 WRX
Sonic Yellow
What are you doing? Normal fuel filter replacement? Get some screwdrivers and do it yourself. Look in this pic, behind the washer fluid tank on the upper right. See those black lines that come together? In between is the fuel filter.
http://www.iwoc.co.uk/images/my2002/stiukq20.jpg
This is what it looks like, except this pic is upside down.
http://camskill.co.uk/smsimg/85/1078...fuelfilter.jpg
firedust is offline   Reply With Quote
Old 12-25-2005, 09:11 PM   #9
RexyGirl
Member#: 63616
with mods :)
People, people....
On the STi, the fuel filter is in the fuel tank. There is no filter in the engine bay. You have to remove the back seat to gain access to it because it is part of the fuel pump assembly.
P.S. Your owners manual is your friend...
Old 12-25-2005, 10:43 PM   #10
WShade
Member#: 74339
Mine is in the tank. Changed it while I was upgrading my fuel pump.
WShade is offline   Reply With Quote
Old 01-25-2007, 11:21 PM   #11
dan2304k
Member#: 36943
For all those who have been wondering, here is the STI fuel filter. The part number is 42072FE020. It's $62 from subaruparts.com
dan2304k is offline   Reply With Quote
2004 sti fuel filter location?? someone help sycklylow Service & Maintenance 4 09-02-2008 09:03 PM
Fuel Filter replacement - where is fuel pump relay? SeenDubAYouAreEx Newbies & FAQs 4 07-11-2007 09:29 PM
Fuel filter location ? Rally Monkey Service & Maintenance 3 02-11-2004 01:19 AM
where is the fuel filter located? linus011 Newbies & FAQs 2 04-10-2003 11:06 PM
Where is fuel filter tmaler13 Newbies & FAQs 2 07-03-2002 10:39 AM
