Old 12-24-2005, 03:05 PM   #1
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default RH Service Hole Cam O-ring
I've had a small oil leak for over a year now and today I decided to fix it. Since I couldn't find any photos of such a common oil leak, here are some photos of the passenger side service hole cam o-ring.
Removal:
1. Remove two (2) 12mm bolts holding plate to the back of the engine.
2. Rotate the assembly in a twisting motion to pull in out smoothly.
3. Remove old o-ring and install the new (806946030) being careful not to scratch any surfaces.
4. Carefully square the assembly up in the bore and gently rotate/twist the assembly in until it is flush with the engine.
5. Align bolt holes and tighten two (2) 12mm bolts to 4.7 ft-lb or snug them up with a 1/4" ratchet.
The cam o-ring is around $4 from Subaru.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 12-24-2005, 06:49 PM   #2
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Hey, I found a ratchet exactly like that in a used car, with a 3" extentsion and a 10mm deep socket
-paK +1
Pakin is offline   Reply With Quote
Old 12-25-2005, 10:56 AM   #3
avk
Member#: 17252
'06 WX8
59E
There's another O-ring, same part number, at the opposite corner of the engine, between LH cylinder head and camshaft support in the front. It can leak just the same. I hope to do mine with the timing belt.
avk is offline   Reply With Quote
Watching the watering hole cam...i think someone just died kaisersouse Off-Topic 10 12-26-2006 02:11 PM
Part number: Service Hole Cover sti_my05 Newbies & FAQs 3 08-08-2006 08:09 PM
cam o ring emyselfandi Service & Maintenance 4 01-01-2006 10:07 AM
ca: mini pin hole cams 949 Private 'For Sale' Classifieds 38 01-19-2005 05:12 AM
CA pickup only pin hole cams 949 Private 'For Sale' Classifieds 1 09-27-2004 12:44 PM
