Old 12-25-2005, 12:26 AM   #1
WRXminion
Member#: 37579
2003 WRX
Default weird lurch
so I was driving back to Tulsa from collage, boulder Colorado, for winter break.
After about ˝ (4-5hours) way threw the trip my car did something weird. It lurched… it felt like I took my foot off the gas and then gave it gas really fast… or when someone is learning to drive a clutch and the car does that weird lurch forward…. It only did it a few times. It also would do it under constant throttle… not with the cruise control.
I’m assuming it might be something with my electrical system. I’m changing out my battery, Optima, and going to denso 1 step cooler plugs. I'm doing this for general maintenance anyway. Any one recommend a different battery or plug?
Any other ideas?
WRXminion is offline   Reply With Quote
Old 12-25-2005, 12:56 AM   #2
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
What are you studying in collage?
Seems like this would be more of a fuel problem. Ever change your fuel filter?
Things like this are often pretty hard to diagnose until you can reproduce the problem...bummer.
specialev is offline   Reply With Quote
Old 12-25-2005, 02:54 AM   #3
WRXminion
Member#: 37579
2003 WRX
yea, it might be a fuel problem.
I changed the fuel filter at about 30k, I just hit 70k, i might change it again.
I'm about ot upgrade to a vf34, fuel pump, and injectors... might also fix the problem.
it's not a recuring problem, so ohh well
ohhh, i'm a double major, getting a BS in Buis: managment. and a BFA in photography
Weird metal clunking, lurching when turning OCrex Brakes, Steering & Suspension 17 03-31-2011 09:51 PM
lurching + CEL = ? dead-eye Normally Aspirated with bolt-on Forced Induction Powertrain 3 10-22-2002 01:14 PM
Back and forth lurching in low gears on a 2002 WRX 5MT sedan! Maniac Transmission (AT/MT) & Driveline 11 09-30-2002 11:15 AM
Lurching question? WR-REX Factory 2.0L Turbo Powertrain 1 12-05-2001 09:51 AM
need help diagnosing a lurching problem Travis R General Forum Archive 2 12-12-2000 07:43 AM
Message Board Statistics All times are GMT -4. The time now is 11:17 PM.
