Old 12-25-2005, 09:42 PM   #1
d4ygl0
Member#: 101964
2011 WRX Limited
Default How to change an fuel filter on an '02 wrx wagon
Ive searched and searched, but i just cant find a thread that specifically helps me do this...just that everyone says that its easy to do. Any tips or step by steps on how to change the fuel filter (OEM) people can point me towards would be great.
thanks.
d4ygl0 is offline   Reply With Quote
Old 12-25-2005, 09:49 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
sorry it's sideways
Old 12-25-2005, 09:50 PM   #3
beefstuinit
Member#: 70079
2011 WRX Limited
Metallic Grey
fuel filters aare liftime items these days. why are you changing it on an 02'!??!
beefstuinit is offline   Reply With Quote
Old 12-25-2005, 09:58 PM   #4
wrx2
Member#: 13852
2002 WRX vf22 SOLD
Now E46 M3 Vert
Life time item? I never heard the fuel filter is good for life time.
wrx2 is offline   Reply With Quote
Old 12-25-2005, 10:07 PM   #5
rexsquared
Member#: 71748
2002 WRX Sedan
World Rally Blue
I used this:
Fuel Filter
rexsquared is offline   Reply With Quote
Old 12-25-2005, 10:17 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Not lifetime, the service interval for the external (not in-tank) fuel filters is 30K.
The procedure Scotty posted refers to releasing the fuel pressure, which should be done before removing the filter as follows-
Remove the gas cap. Under the passenger side kick panel next to the glovebox, look for a relay with a green plug (it's next to another one with a brown plug). Disconnect the green plug, that is the fuel pump relay. Crank the engine, it should start and die. Repeat until it cranks for several seconds without starting, do that a couple of times. Now you can remove the lines from the old filter, but keep a rag handy as there may still be some residual pressure left in the lines even after performing the previous steps. Also note that the lines may be difficult to remove from the filter, you might need to use a pliers to twist them off if they're stuck. Once off it's just a matter of removing the old filter and installing the new one.
With the new filter in place and the lines tightened up, plug the relay back in and put the gas cap back on. Turn the key from off to run a couple of times, and hold it there for several seconds, to run the fuel pump and prime the system. Then start the engine and check around the filter for any leaks.
Old 12-25-2005, 10:19 PM   #7
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Ah, what? Fuel filters are FAR from lifetime items. Whoever gave you that advice stay clear.
cdvma is offline   Reply With Quote
Old 12-25-2005, 10:33 PM   #8
d4ygl0
Member#: 101964
2011 WRX Limited
awesome guys thanks so much! ill be doing this tomorrow morning or the day after, so ill let you know how it goes.
thanks again
Old 12-26-2005, 10:10 PM   #9
ryan_o
Member#: 103096
2003 WRX
I used the info from scoobymods. Piece of cake. Now if I can only find a place that sells shockproof gear oil.
ryan_o is offline   Reply With Quote
Old 12-27-2005, 05:33 AM   #10
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
This is going to sound harsh and I dont mean it to be. If you need a 'how to' to change a fuel filter, you probably shouldnt be doing it.
BVM is offline   Reply With Quote
Old 12-27-2005, 09:30 AM   #11
subaruwrx420
Member#: 80939
^^^That's crap because I didn't know how to change the oil in a car before I got my wrx...since then I have done, suspension, up, tbe, gauges, oil cooler, brake lines, and 30k service.
It's better to encourage people not discourgage them.
subaruwrx420 is offline   Reply With Quote
Old 12-27-2005, 09:33 AM   #12
subaruwrx420
Member#: 80939
d4ygl0...I used the instructions on Scoobymods. I did not empty the fuel system like others have suggested. When I disconnected the hoses a little fuel leaked out but not too much. The problem was that the filter itself was full of fuel and it spilled in my car on the way to dispose of it. If you have it, put a little grease on the new filter connections past the actual opening...it will make removing the hoses easier the next time. Good luck.
Old 12-27-2005, 12:17 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
...all I did to de-pressure the fuel system was remove the gas cap and went in to have lunch and did the filter after lunch......and 420 is right .....that damned filter holds a LOT of gas!!!!....be careful with it when ya get it loose 'cuz THAT is what leaks a lot of fuel....NOT the lines
Old 12-27-2005, 04:37 PM   #14
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
I encourage people to understand their limits and mechanical knowledge. If you cant undo 1 clip and three hose clamps without a technical guide, you should not be attempting to replace the fuel filter. PERIOD! Its FUEL, HIGHLY PRESSURIZED FLAMMABLE FUEL.... don't you understand? I have been a certified mechanic for 15 years. I have seen some really scary '@ home repair' jobs come in the shop. Tinkering with very complex late model cars when you don't have a clue what you are doing, puts not only yourself at risk, but anyone that comes in contact with your car on the road. Trust me, I bet every certified mechanic that is reading this is nodding their head in agreement.
edit because I know my post will be misinterpreted. I am not saying you have to be a certified mechanic to work on your car. I am saying that you really need to have a good idea of what you are doing.
Old 12-27-2005, 05:59 PM   #15
hoodscoob
Member#: 85140
2005 Legacy GT wagon
topazzzzz
try summitracing
hoodscoob is offline   Reply With Quote
Old 12-27-2005, 06:07 PM   #16
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
I didn't bother with any complex depressuring tricks, just let it sit overnight and had no trouble. The hardest part is getting the hoses off the old filter. Be careful doing that so you don't damage the hoses.
But there are some tips that useful to know, like those Mulder gave. What's wrong with asking for advice? Let's face it, a lot of auto work is actually pretty easy for anyone with some mechanical aptitude and decent instructions.
Mike Wevrick is offline   Reply With Quote
Old 12-27-2005, 06:14 PM   #17
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
I agree Mike, I was responding to subaruwrx420's thats crap statement.
Old 12-27-2005, 06:15 PM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
....and I CAREFULLY used an awl pushed under the edges of the hoses and worked around the hardpiping on the filter to break the hoses loose.....it appears to me that there is some sort of adhesive used on the stock filter hardpipe/hoses.
Old 12-27-2005, 06:20 PM   #19
ryan_o
Member#: 103096
2003 WRX
.....I am saying that you really need to have a good idea of what you are doing.
That's why I read and search and read more. All right here on this forum. I am by no means a mechanic but I think this is fairly simple to learn. I couldn't even point out the filter before I searched the subject.
Originally Posted by hoodscoob
try summitracing
Thanks but I finally found some locally after calling 15 places.
Old 12-28-2005, 02:31 PM   #20
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
The thing that stumped me was disposal of the old used fuel filter. I finally called the county "household hazardous waste" center and found out that even here in eco-land, there's a big loophole:
as long as you drain out the liquid from the filter (gas from a fuel filter, oil from an oil filter), it is no longer considered hazardous waste and you can throw it in your normal trash! Of course, you still have to dispose of the liquid gas properly, but that's a lot easier.
how to change license plate bulb on 08 wrx?? necno3 Newbies & FAQs 10 10-06-2009 11:02 AM
2005 WRX 4eat, do I need to change the fuel filter? eurospek Service & Maintenance 12 02-24-2009 12:42 PM
Quick: how the F do you get the gas linesoff the fuel filter on an Impreza? poison Off-Topic 55 03-20-2008 07:53 PM
Changed my fuel filter on my 2004 wrx kccobra Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-17-2006 11:09 AM
is there a proper way to change my fuel filter? RugDoc2003 Service & Maintenance 31 03-10-2003 02:01 PM
