Old 12-26-2005, 12:53 AM   #1
trite
Member#: 81658
2007 STI
Default SMC alcohol injection failure???
Has anyone had an SMC alcohol injection system fail causing motor failure in their wrx?
trite is offline   Reply With Quote
Old 05-28-2009, 09:34 PM   #2
robwrx19720
Scooby Scammer- Do Not Buy From User
Member#: 180582
nnooo
robwrx19720 is offline   Reply With Quote
Old 06-03-2009, 02:32 PM   #3
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
Mine works great
Cards2323 is offline   Reply With Quote
Old 06-03-2009, 07:03 PM   #4
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
Steve has great customer support. SMC system working for 3 yrs.
SurfWagon is offline   Reply With Quote
Old 06-11-2009, 11:39 AM   #5
lcesardo
Member#: 158841
I`ve recently noticed that my smc controller has the yellow light on permanently.
That light is only supposed to be ON when alcohol is being injected, but in my case
it`s on as soon as I start up the car, both lights, green and yellow, anyone has had
this issue and solved it?
lcesardo is offline   Reply With Quote
Old 06-15-2009, 05:18 PM   #6
lcesardo
Member#: 158841
anyone?
Old 06-15-2009, 05:21 PM   #7
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
check your boost settings on the controller
is your pump actually pumping or is it just the light
check wiring
call smc
krambte79 is offline   Reply With Quote
Old 06-15-2009, 05:23 PM   #8
VWGrk1
Member#: 57882
2004 WRX
Check your ground. The light stays on if it is not grounded.
VWGrk1 is offline   Reply With Quote
Old 06-16-2009, 06:36 PM   #9
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
i recently had a issue with my spray light flickering and not coming on when in boost. i pressed the test button and it sprayed without the light coming on... weird.
i called steve and he told me to do a pump pressure test which turned out great. so i replaced the vaccum line for the boost source and ever since didnt have this issue. weird.
ownnij is offline   Reply With Quote
Old 07-22-2009, 12:14 PM   #10
lcesardo
Member#: 158841
you were correct, it was a ground problem... my mechanic forgot to
ground it... so I solved that problem right away, but now I started
to notice that the spray light turn on randomnly, not at the desired
boost setting, but at idle or even when no boost was on...
Im gonna try with the vaccum line...
Old 08-11-2009, 10:03 PM   #11
Dak Jones
Member#: 220149
2004 Subaru WRX STI
WRC Blue
Please help. I have a SMC methanol injection system installed on my 2004 sti. Everything has always worked fine untill i took it to a mechanic to have a new ACT 6 puck clutch kit and new light weight flywhee installed. The garge i went to was recomended by a guy i know that has multiple high performance, highly modified cars.
I went for a ride after the install to break in the new clutch and found that the car felt under powered compaired to usual. The car makes 454 whp spraying meth. I noticed that the indicator light on the dash control module that let you know that the system is armed was lit as it should be but at 10 PSI the system should spray but does not. No spray at all. The mechanic said that all he did with the electrical system was pull the batery. I checked the ground wires for the meth pump, they were fine. I am really upset about this. I worked fine when i took it to this guy. I just noticed it today and the mechanics shop is closed so i havent had a chance to bring the car back to the shop. I reset my map with my access port to the 26 psi + meth map because the ECU had reset after they pulled the battary. Can anyone help me? I tried the spray test and nothing happend.
Dak Jones is offline   Reply With Quote
Old 08-11-2009, 10:07 PM   #12
ownnij
Member#: 70459
you should call smc. is the green light on? your pump might have failed because it triggers the spray light.
Old 08-11-2009, 10:08 PM   #13
Dak Jones
Member#: 220149
2004 Subaru WRX STI
WRC Blue
This sounds like the other guys problem but my spray light will not come on and the test did not spray. I think its grounded. Should the ground wire be attached to the bolt on the right of the meth bottle?
Old 08-11-2009, 10:10 PM   #14
Dak Jones
Member#: 220149
2004 Subaru WRX STI
WRC Blue
the green light is on but it is definatly not spraying. I noticed a huge lose in power.
Old 08-11-2009, 10:12 PM   #15
Dak Jones
Member#: 220149
2004 Subaru WRX STI
WRC Blue
do you think SMC will be able to help. I am affraid that the mechanic that installed the clutch will tell me that he did nothing but pull the battery.
Old 08-12-2009, 02:47 AM   #16
sleeperrex
Member#: 19466
2002 wrx/hybrid
My green light does not turn on but it does spray.
sleeperrex is offline   Reply With Quote
Old 08-12-2009, 09:07 AM   #17
ownnij
Member#: 70459
^^^ seems like a common issue with smc kits but as long as it sprays then it's good. i think what happens is that the led has gone bad.
Which top mount intercoolers work with the SMC alcohol injection system? aprazma Water/Methanol Injection, Nitrous & Intercooler Cooling 58 01-26-2007 04:29 AM
Anyone running smc alcohol injection? trite Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 51 11-05-2005 12:47 AM
SMC Alcohol Injection Kit AK*WRX*2004 Private 'For Sale' Classifieds 7 10-13-2005 08:55 PM
SMC alcohol injection for WRX MisterX Private 'For Sale' Classifieds 5 07-22-2005 06:43 PM
SMC alcohol injection kit: run 91 octane+ kit= same as 100 octane in the tank gnx7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-25-2002 03:57 PM
