Old 12-26-2005, 01:56 AM   #1
t1h9o8m6s
Member#: 66482
2004 WRX
Java Black Pearl
Question too much oil?
So I did an oil change without doing the filter today. I added 5 quarts of new oil but forgot about the amount of oil that's still in the filter. I checked the dipstick a few hours later and the oil comes up to the uppermost dot (the one above F). Should I be worried about potentially damaging anything?
t1h9o8m6s is offline   Reply With Quote
Old 12-26-2005, 04:19 AM   #2
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
1) why would you change the oil and not the filter
2) get the oil between the F/L dots or at the top F dot
overdose is offline   Reply With Quote
Old 12-26-2005, 09:54 AM   #3
Hayes
Member#: 11808
No problem if the oil is not over the notch or dot above the full hole. The notch is the recomended hot high oil level.
Hayes is offline   Reply With Quote
Old 12-26-2005, 11:51 AM   #4
BillJC
Member#: 31002
I still think the real question here is why did the oil change get done without a filter change...
BillJC is offline   Reply With Quote
Old 12-26-2005, 12:03 PM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Ditto.
You will probably be complaining next that you smell oil burning. Drain some out, or suck it out trhough the filler tube.
BTW, I believe the owners manual has a listing for for replacement quantity with/without a filter change. Can't figure out why since a filter is only ~$4.
Old 12-26-2005, 12:16 PM   #6
AC7880
Member#: 76589
2005 WRX Wagon
Platinum Silver
Manual says 4.2 quarts with the filter. You need to drain some oil.
AC7880 is offline   Reply With Quote
Old 12-26-2005, 02:23 PM   #7
t1h9o8m6s
Member#: 66482
2004 WRX
Java Black Pearl
Thanks for the replies. I'm going to replace the filter which hopefully will drain enough oil to put me back where I'm supposed to be.
Ekk think I added too much oil for my oil change.. sti. NewShockerGuy Service & Maintenance 13 03-17-2005 05:15 PM
Effects of too much oil JenisonWRX Newbies & FAQs 9 01-28-2002 02:22 AM
Too much oil causing sluggishness? Marc Sawaya Normally Aspirated Powertrain 10 07-08-2001 02:36 AM
need answer fast! too much oil, bad? pbnj9786 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-06-2001 09:55 AM
