Old 12-26-2005, 11:54 AM   #1
BBBsti LTD
Member#: 71682
2007 WRX Sti LTD.
Default How hard to remove heat shield on cilinder #4 for EGT???
I have to replace the EGT probe but I dont know how many bolts hold the shield. The probe defective probe is already installed and the heat shiled has the hole for the EGT so the installation should not be that difficult. But I'm not sure.....
BBBsti LTD is offline   Reply With Quote
Old 12-26-2005, 12:40 PM   #2
testes1010
Member#: 47145
2012 Gas Saver
its easy...3 bolts hold the heat shield on (12mm socket IIRC)
testes1010 is offline   Reply With Quote
Old 12-26-2005, 03:25 PM   #3
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
Yup, easy.
Let some Liquid Wrench soak into those bolts before you try to break them loose.
02WHITEDUB is offline   Reply With Quote
how hard to remove intake manifold?? skate enjoi Interior & Exterior Modification 7 09-14-2006 02:34 PM
How to remove heat for Liquid cooling? StealthfishWRX Off-Topic 18 09-08-2005 06:10 PM
how important is a heat shield once ive got a downpipe on? bluebaru wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-10-2004 08:24 AM
How hard to remove/install rear bumper?q AWDconvert Bay Area Impreza Club Forum -- BAIC 2 05-08-2003 10:42 AM
changing oil, how to remove plastic shield Retro Service & Maintenance 4 08-15-2002 11:35 PM
