Old 12-26-2005, 04:39 PM   #1
renda85
Member#: 101330
2002 STI V7 Spec C
Angry window washer no pressure?
Well itís been a good while now; my window washer nozzles have absolutely no or very little pressure. It doesnít even reach the windshield? Nothing is clogged I donít think, I used needles and tried cleaning the nozzles but no go. But every now and then when Iím stopped its spray perfectly? But on highway or driving at 40mph it doesnít work. Is my pump done? What do I have to replace? Thanks! Ps: I drive a 2002 wrx
renda85 is offline   Reply With Quote
Old 12-26-2005, 06:42 PM   #2
mike_b49431
Member#: 101240
2005 Impreza RS
Crystal Grey
You might check for a pinched hose, other then the motor being shot, thats the only thing i can think of...can you hear the motor going when your not getting any fluid.
mike_b49431 is offline   Reply With Quote
Old 12-26-2005, 07:38 PM   #3
renda85
Member#: 101330
2002 STI V7 Spec C
Pinched hose!
Old 12-26-2005, 07:47 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Add another for the hose that is pinched.
Old 01-03-2006, 10:15 AM   #5
John UK
Member#: 81042
2000 5 door turbo
If you simply pushed a needle into the nozzle, you may have just pushed the blockage back into the chamber behind the nozzle. After a while, the blockage can gmake it's way back to the jet. That's the only way I can think of the problem coming and going.
The way to clean this is to disconnect the washer pipe from the jet and wash it out backwards. ie, force water down through the jet.
Good luck.
John UK is offline   Reply With Quote
Old 01-04-2006, 08:02 PM   #6
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
Could also be that you're getting air into the line due to a hole in one of the hoses or a wrong size hose. At one point I changed the washer fluid hoses out for some silicone ones. After a while I had no pressure, it was because the new hose was a bit too big and not sealing on the nipples of the washer nozzles.
khail19 is offline   Reply With Quote
Old 01-04-2006, 09:58 PM   #7
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
nipples, hoes-ez, yes, no kinkyness
overdose is offline   Reply With Quote
Old 01-04-2006, 10:33 PM   #8
Hayes
Member#: 11808
I had the same problem and found check-valves sticking. There is a valve under the hood in each of the water lines. I removed the valve and all was well. The plastic valves had a small notch wore in the seat that was causing the problem. I replaced the valve with a plastic barbed connector from AutoParts.The valve was there to prevent the washer solution from draining back out of the tubing. Leaving the valves out requires about an additional 1-2 seconds for the tubing to reprime before water hits the windshield which to me was no problem. Try it. Ed
Hayes is offline   Reply With Quote
Old 01-05-2006, 04:59 AM   #9
John UK
Member#: 81042
2000 5 door turbo
The down side is that the wipers sweep for those couple of seconds on an almost dry dirty (gritty) screen before water gets there. This can wear the blades and scratch the screen.
It does have the advantage that there is no water left in the jets to freeze in the winter.
Your choice.
Old 01-06-2006, 01:54 PM   #10
labrat
Member#: 24533
2002 WRX Wagon
mbp
I had the same problem also with the check valves. Found that the valves were clogged with some gummy deposit (turned out that the wiper fluid that I had been using wasn't compatible with what the non-dealership shop used at the last service; the resulting mixture threw a precipitate that gummed up the check valves). Ultimately, I had to drain the wiper fluid reservoir, and replace the check valves (they were a few bucks for a pair).
labrat is offline   Reply With Quote
Old 01-15-2006, 04:13 AM   #11
sith
Member#: 66362
2001 GM6 V7 STi
Black with rust
anyone got part numbers for the valves? i got the same problem on my 01RS, the passenger side just dribbles out.. the drivers is fine... i hope this will fix it..
.sith.
sith is offline   Reply With Quote
Window washer sprayer - what positions? HappyK Newbies & FAQs 10 03-09-2009 01:57 AM
Rear window washer fluid 85hstock Interior & Exterior Modification 2 01-02-2005 05:54 PM
in a sedan, can you wire up the rear window washer? idealrides Electrical & Lighting 6 03-28-2004 02:43 AM
