Old 12-26-2005, 07:49 PM   #1
willz23
Member#: 52954
08 FXT Sport
Default Jacking Rear Diff
Hey guys,
I was wandering what kind of floor jack everyone was using to jack up their rear differentials so they can put their cars on jack stands.
Thanks
Will
willz23 is offline   Reply With Quote
Old 12-26-2005, 07:54 PM   #2
kts262
Member#: 45464
91 E30 325i
95 E36 325is
I got the Craftsman "lightweight" Aluminum jack. It's red/silver and weights about 40 pounds or so. They run about $90-100 at Sears. Works great, much better than a cheaper and lighter jack I bought before.
kts262 is offline   Reply With Quote
Old 12-26-2005, 11:59 PM   #3
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
I have the same one and it works great!!!
http://www.sears.com/sr/javasr/produ...id=00950240000
Hank3 is offline   Reply With Quote
Old 12-27-2005, 06:29 AM   #4
Hayes
Member#: 11808
Which ever you use, put a 2X4 pad on the jack plate to protect the differental.
Hayes is offline   Reply With Quote
Old 12-28-2005, 02:33 PM   #5
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Costco rules! Hard rubber, like a hockey puck, works well too on top of the jack plate.
Old 12-29-2005, 07:12 AM   #6
DChan
Gone... But not forgotten
Member#: 60342
2004 STi
I have the low profile one from Griots Garage. They took it off their site tho.
DChan is offline   Reply With Quote
Old 12-30-2005, 05:11 PM   #7
hikeeba
Member#: 89165
Poop Stuck Survivor
-=C=- & subari87 FOREVER!
I've got a 2.5 ton $55 Advance Auto Parts something-or-other jack. I cut up an old pair of Tevas to make a saddle pad. Works pretty good.
I've heard of folks buying the rear diff protector to use as a jacking point. I'm a little skeptical about doing that. I think that piece was created to protect the diff from debris and such; not to support the weight of the rear of the car. Correct me if I'm wrong.
hikeeba is offline   Reply With Quote
Old 01-28-2006, 11:16 PM   #8
UK2TX
Member#: 15026
If the diff protector can protect the diff from a moving car bouncing on it I would think that it would be fine to use it as a jacking point....especially with a 2x4 inbetween.
UK2TX is offline   Reply With Quote
Old 01-29-2006, 04:30 PM   #9
solbey11
Member#: 89234
The diff protector is there to keep debris from flying up and damaging your differential. And for running over large rocks and such. It wasn't designed to hold the weight of the entire rear end. It may be possible, but I'm willing to bet overtime it will bend.
solbey11 is offline   Reply With Quote
Quick question about jacking up from rear diff? skydes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-09-2007 03:27 PM
Stickier shift after jacking by rear diff glider Transmission (AT/MT) & Driveline 4 02-19-2007 05:52 PM
Ok to jack by the rear diff? Bravoe6 Newbies & FAQs 4 01-29-2007 04:10 PM
rear diff. good for jacking point? g0tb00st Brakes, Steering & Suspension 6 09-24-2004 02:28 PM
Jacking car up by rear diff - OK??? mykrrrr Newbies & FAQs 18 12-01-2000 10:35 AM
