Old 12-26-2005, 08:04 PM   #1
JDM 3SGTE
Member#: 35479
Default Normal to have to calibrate wideband after 3 weeks?
ive had my innovate lc-1 installed for about 3 weeks now, and yesterday while i was logging i noticed some erratic readings. afr were going into 7's when in boost, and while idling it would jump around from 15-18. up until that day i was idling normally around 14.2-15.5. the sensor is mounted right before the near 90* bend on the downpipe at around the 9-10 oclock position, which puts it about 12-16 inches after the turbo. oh and i should mention the weather conditions were very rainy the day of the erratic readings. i plan on taking the sensor out to do a free air calibration sometime this week, but would like to know if this has happened to anyone else, for some peace of mind.
couple other (possibly) unrelated questions:
1. my afr goes static to 10.42 after a few seconds of being completely off throttle. is this just a error because the sensor cant read that lean?
2. i thought that injectors shut off when engine braking, but logs show inj duty at 4.x% when decelerating in gear. have i just been misinformed?
JDM 3SGTE is offline   Reply With Quote
Old 12-26-2005, 10:15 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...bad wire/ground....mebbe
Old 12-27-2005, 11:23 AM   #3
hondaeater69
Member#: 60324
sounds like the sensor may be caput. not normal for it to acting like that.
Old 12-27-2005, 11:43 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
...or an exhaust/intake leak...mebbe
Old 12-27-2005, 12:06 PM   #5
Gethin
Member#: 2998
Also make sure that the cables and harness does not get wet / damp.
Gethin is offline   Reply With Quote
Old 12-27-2005, 03:31 PM   #6
flwrx
Member#: 35944
'03 v7/6mt/30r wrx
MBP
I had that problem w/ my LC1. Mine was caused by the calibration wire grounding out, causing it to recalibrate itself while driving.
flwrx is offline   Reply With Quote
Old 12-27-2005, 07:21 PM   #7
JDM 3SGTE
Member#: 35479
recalibrated today and all is normal. weird. maybe i hit the recalibration button by accident?
oh and i was hesitant to calibrate while engine braking because the utec logs show injectors at 4.x% as the revs are coming down, but according to cdvma at wrxhackers the injectors are off even though logs show otherwise. tried it, and idles exactly where it used to.
Old 12-27-2005, 07:24 PM   #8
JDM 3SGTE
Member#: 35479
where did everyone mount theirs? i mounted mine right on the firewall behind the intercooler. could it be that water somehow got to it? i thought of that as i installed it but figured the stock scoop splitter would keep everything sealed.
Old 12-27-2005, 08:03 PM   #9
Member#: 67
1999 Outlasting
the competition.
ZT-2 for the win
i gave up with the Innovative units. I had too much trouble with them that i sent them all back and got the Zeitronics unit and been happy for the past 6 months with it
tom
Old 12-28-2005, 09:10 AM   #10
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
do you have a utec?
Old 12-28-2005, 02:39 PM   #11
JDM 3SGTE
Member#: 35479
yes i am a utec owner.
Old 12-29-2005, 02:34 AM   #12
sideways7
Member#: 49428
i was having some erratic readings also. called innovate. they told me the sensor needed to be at least 3 ft. from the turbo. i didnt notice the instructions mentioning that and i mounted mine right after the turbo on the top of my helix dp, maybe 6 inches back. so needless to say i fried the sensor.
sideways7 is offline   Reply With Quote
Old 12-29-2005, 08:30 AM   #13
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
ok, since you're a utec owner:
1) does the afr go steady above 5500 rpms or below it? below that point is ecu control, above that point is utec OLF control, and that will NOT shut off injectors even if the throttle is closed.
2) the utec has trouble showing zero IDC. as a result it tends to repeat the last non-zero IDC value when in fact the injectors are not firing. this will happen as rpms drop below 5500.
hth
ken
Going to Iceland in a little over 3 weeks for my Bachelor Party. Mud Pig Off-Topic 51 05-11-2009 04:46 PM
looks like im goin to have to go to dealership to rip me of $500 luca b. Service & Maintenance 4 10-10-2006 08:09 PM
Sorry to have to to this, Kiwi. SLDWYS Alaskan Impreza Club Forum -- AKIC 2 02-24-2006 07:57 PM
would any one be down to have a meet in stockton next week at the asparagras festival scoobydoo02 Bay Area Impreza Club Forum -- BAIC 5 04-23-2002 09:12 PM
after 3 weeks they are FINALY in ^jynx^ New England Impreza Club Forum -- NESIC 3 07-15-2001 10:49 AM
