Old 12-26-2005, 11:25 PM   #1
imprezaBlue
Member#: 40463
Have a Nice Day? what gas mileges you are getting from stock and with utec stage 2 set up?
i am only getting 10~13 miles per gal.
thanks.
imprezaBlue is offline   Reply With Quote
Old 12-26-2005, 11:34 PM   #2
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
Not utec, but my STG 2 AP gets 20-21 mpg with mixed driving. Your stuff is b0rked.
J-Rex2004 is offline   Reply With Quote
Old 12-27-2005, 12:14 AM   #3
bigworm
Member#: 87024
2005 pp psm wrx with
mix of v6,7,8 sti parts
ap here to with a 4.44 tranny stage 3ed i get 18 on the low side
bigworm is offline   Reply With Quote
Old 12-27-2005, 01:50 AM   #4
io1029
Member#: 78993
2005 WRX
TGV, begone!
I know you said UTEC, but with my AP stage 2 (15.8PSI max boost) I am getting about 17MPG at the lowest. That is pretty much flogging it nonstop with lots of short trips.
If I mix in some "normal" driving and highway I go from 22 to 28 MPG normally.
I'd say you have an issue
io1029 is offline   Reply With Quote
Old 12-27-2005, 01:53 AM   #5
io1029
Member#: 78993
2005 WRX
TGV, begone!
Btw, over how many tanks of gas have you noticed this level of MPG?
A couple of times I've filled up, driven maybe 80-100 miles, done work on my car and reset my ECU by disconnecting the battery, which resets the trip odometer. Next time I filled up I thought I was only getting like 10MPG, till I realized I had reset everything.
Old 12-27-2005, 03:41 AM   #6
Gethin
Member#: 2998
Is it a tuned stage 2 UTEC setup? I hope not!
The stage 2 map is very rich, my car ran down to a horrible 9.5:1 AFR WOT with the stock stage 2 map, wich resulted in crappy gas milage and hesitations. I had to remove a ton on fuel. I run 94 octane. The basemaps are "tuned" for 93. The basemaps are not designed to be used as your daily map, just a safe way to get you on the road for you to tune it yourself or to the shop for a professional tune.
Gethin is offline   Reply With Quote
Old 12-27-2005, 10:05 AM   #7
WRC-Go
Member#: 29917
2017 WRX
With AP STG 2, I'm still getting the same all-around - 22-23 mpg...
WRC-Go is offline   Reply With Quote
2005 STi for sale. 25,xxx miles, Stage 2 set-up [email protected] Private Vehicle 'For Sale' Classifieds 12 08-15-2009 03:16 PM
FS: Stage 2 set up 04Silverex SCIC Private Classifieds 0 04-28-2008 05:10 PM
stage 2 set up? toyo764 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-02-2008 10:48 PM
FS: Cobb Stage 2 set up for 2004 WRX $550 shipped phillepe Engine/Power/Exhaust 8 03-28-2008 04:29 AM
What is your Stage 2 Set up? wonsin83 Newbies & FAQs 83 05-06-2007 01:04 PM
