Old 12-26-2005, 11:19 PM   #1
Impreza01
Member#: 152
2002 Impreza WRX
Question Center Differential: Tread size difference
Recently I had to replace a tire due to a pothole damaging the sidewall. The place I went to only had 2 Pzeroneros. Thus I changed two tires with the fronts being new and the rears being the old ones. Now I asked the mechanic to measure the tread difference. He measured twice and the difference came out as 2 mm.
Is 2mm big enough to create concern for premature center differential wear/tear?
Impreza01 is offline   Reply With Quote
Old 12-27-2005, 12:23 AM   #2
makofoto
Member#: 25243
2006 Legacy Outback
Tire Rack says 3/32nds (tread depth difference) ... about 2mm ... you're probably OK.
Best is to order replacement tires from TireRack shaved to match your "leftover" tires.
makofoto is offline   Reply With Quote
Old 12-27-2005, 12:25 AM   #3
makofoto
Member#: 25243
2006 Legacy Outback
Xxxxx
Old 12-27-2005, 10:55 AM   #4
subieworx
Member#: 47769
I believe Subaru states 1/4" ~ 6.35mm so you are fine. The questions is, did the mechanic measure correctly?
subieworx is offline   Reply With Quote
Old 12-27-2005, 12:45 PM   #5
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
subaru says 1/4" (6.35mm) in circumfrence.... So that is pi*d wich gives us 4mm difference in d and results in a value of 3.1415*4=12.56... double the acceptable value.
of course you could adjust air pressure to compensate.... (what that will do to your handling Im not too sure)
LyveWRX is offline   Reply With Quote
Old 12-27-2005, 12:50 PM   #6
makofoto
Member#: 25243
2006 Legacy Outback
good idea with the tire pressure. For street driving doesn't make that much difference. Oem pressures are too soft anyway ... compromise between comfort and performance.
Old 12-27-2005, 01:00 PM   #7
subieworx
Member#: 47769
Ah yes, stand corrected. good catch.
Old 12-27-2005, 04:22 PM   #8
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
So, when you reduce the air pressure, at what point does the tread 'skip' those few millimeters in it's circumference? can you feel it skip?
Carl
1 Lucky Texan is online now   Reply With Quote
Old 12-27-2005, 04:26 PM   #9
makofoto
Member#: 25243
2006 Legacy Outback
I would increase tire pressure on the "shorter" tires instead of decreasing on the new tires.
Old 12-27-2005, 04:40 PM   #10
subieworx
Member#: 47769
Carl
I was talking about the circumference catch, not the air pressure catch.
tread size difference, with a twist davrex Tire & Wheel 2 05-13-2010 06:18 PM
Front/Back Tire Tread Wear Difference on '03 WRX Protocol Tire & Wheel 6 09-03-2005 01:04 PM
Size difference between '02-'03 & '04 RSB Call_me_Tom Brakes, Steering & Suspension 9 03-10-2005 01:38 PM
question about tire size differences?? blackie Tire & Wheel 2 02-08-2005 03:35 PM
Extreme center tire tread wear question spshultz Tire & Wheel 4 10-28-2003 09:26 PM
