Old 12-27-2005, 02:13 PM   #1
tcmo
Member#: 12817
2013 Legacy 2.5i LTD
Default change tire size?
I have a 1999 Forester and want to change from 205/70-15 to 215/65-15 tire size. Differences in revolutions/mile between the sizes is 0.5-1.0%. The tire width difference is between .2-.35 in, depending on the tire brand. Anyone done this or see any problems? Thanks.
tcmo is offline   Reply With Quote
Old 12-27-2005, 03:14 PM   #2
GuyLR
Member#: 21811
2003 WRX Wag/01 OBS
WRB and SM
You may have the size wrong. The 205/70-15 is almost the same as the 215/60-16. But a 215/65-16 will have a diameter of around 27" versus 26.3" for the 205/70-15. That's about +3% for rolling circumferance. The 215/60-16 has a diameter of about 26.1" and is the stock 16" size for Foresters. A 215/65-16 will probably fit though if you want more ground clearance and fewer revs per mile.
Here's a link to a good tire/wheel calculator
http://gs.tolan-hoechst.com/tirecalc.htm
GuyLR is offline   Reply With Quote
Old 12-27-2005, 03:31 PM   #3
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
You are going to go with a wider, yet ever so slightly smaller diameter tire. If you using the same 15" rims, you are looking at less then .2" more rubber on bith sides of the rim. I'm not 100% sure it can clear the struts and fender, but most likely. Stock sizes are conservative.
here's another one
http://www.discounttire.com/dtcs/infoTireMath.dos
CitySubie is offline   Reply With Quote
Changing tire size- ? for RS guys- ImprezaL Brakes, Steering & Suspension 19 09-04-2005 11:39 AM
Did some reading about AWD and changing tire sizes. BajaT05 Baja Forum 15 05-12-2005 06:59 PM
Changing Tire Size wakawaka9 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-08-2004 11:17 PM
Changing Tire Size from 215/45/17 to 225/45/17 2.2gotboost Tire & Wheel 1 08-28-2003 12:43 PM
changing tire size affects TOM MAC Brakes, Steering & Suspension 6 08-13-2002 12:28 PM
