Old 12-27-2005, 05:01 PM   #1
Chonojake
Member#: 82313
2003 REX WAG
Platinum
Talking Wheel Offsets?
Ok I am looking at buying wheels for my wagon. Is there a specific offset I should keep in mind?
Edit... so I make a post and scroll up to make another search and WHAM i should be slapped.
Tanks
Chonojake is offline   Reply With Quote
Old 12-27-2005, 05:35 PM   #2
cefoskey
Member#: 83961
2014 A5 S-Line 6MT
'06 Triumph D675
offset is heavily dependant the width of the wheels and tires you want to run.
need to know that first.
cefoskey is offline   Reply With Quote
Old 12-27-2005, 06:47 PM   #3
mch
Member#: 30039
2002 wrx wagon
dirt slvr
stock is 55. going less moves the outer edge of the wheel further out. If you go from a 6.5 inch wheel to a 7.5 inch wheel, you have increased the width of the tire by 25.4 mm. If you are trying to maintain the same Hub/wheel relationship then you might want to think about going as low as a 45 offset. This moves the outer lip of the wheel 10mm outward and will allow for the other 15mm to go inward.
Some cars (the wagons for example) have big trouble with the inner fender liners if you go much below a 55 offset. So, the simple answer is stay around 50 and you should be good to go. If in doubt, ask the vendor and here about specific rims on a specific car.
mch.
mch is offline   Reply With Quote
will lower wheel offset push wheels out giving wider stance? Cusco Tire & Wheel 8 02-03-2003 02:20 AM
what determine wheel offset? can I take vw wheels and rotors? etam Brakes, Steering & Suspension 9 05-27-2002 02:32 PM
Wheel Offset for 90-91 Legacy Peter Hadfield Legacy Forum 3 05-08-2001 05:42 PM
What Wheel Offset is right for a lowered Legacy? MY99 2.5GT Legacy Forum 15 04-14-2001 12:17 AM
wheel offset??? kastle SVX Forum Archive 5 11-27-2000 10:01 PM
