Old 12-28-2005, 01:45 PM   #1
meat_WRX
Member#: 96919
2004 sti
black
Exclamation noise at higher speeds and the hood comes up ***
so when im cruising at arround 85 and up the hood starts coming up off the body, but only above the headlights, the hood latch is secure! this is my 06 and the dealer wont do anything because thoes arent safe speeds.... he said the car wasent built to go 80...HAHA. also theres a LOUD whistling sound arround 120-140, im thinking thats from the hood somewhere. any suggestions, i figured hood pins.
meat_WRX is offline   Reply With Quote
Old 12-28-2005, 03:01 PM   #2
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
The whistling is normal, comes from the rear view mirrors. As for the hood, if you look at the frame under the hood, on the top of the beam right behind each headlight there should be a black rubber/plastic spacer/nub that the hood rests on when closed. You can turn these one way or the other to make them taller or shorter. Adjust them so they're tall enough to keep the hood "snug" when closed.
High pitch whistling noise at higher RPM but not WOT bnr34rb26dett Service & Maintenance 6 06-23-2009 10:39 PM
Creaking at slow speed, squeaking at higher speeds PowerMatt Legacy Forum 6 12-22-2006 03:12 PM
Wastegate noises at higher boost? stang-spanker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-15-2004 09:32 AM
Steering wheel shudder at higher speeds jay25RS Brakes, Steering & Suspension 6 06-05-2004 08:24 PM
Pulling to the left at higher speed wheeljack Service & Maintenance 6 11-06-2002 12:55 PM
